3796.1
3796.1
    CONTA-CLIP
    END PLATE
3796.1 数据手册
Data sheet 3796.1 ZAPT 2,5/2A GN End plate, Width: 1.5 mm, Colour: Green Business data Article number 3796.1 Article name ZAPT 2,5/2A GN GTIN (EAN) 4044211108175 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 2.4 g Weight per piece (including packaging) 2.51 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3796.2 Product description End plate Creation date 17.12.2023 09:03:42 Subject to technical changes 1 Data sheet 3796.1 ZAPT 2,5/2A GN Technical data Dimensions Length 68 mm Width 1.5 mm Height 31.2 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Conform Yes REACH Candidate Substance Note No Creation date 17.12.2023 09:03:42 Subject to technical changes 2 Data sheet 3796.1 ZAPT 2,5/2A GN Media Creation date 17.12.2023 09:03:42 Subject to technical changes 3 Data sheet 3796.1 ZAPT 2,5/2A GN Accessories ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3616.2 ZTRK 2,5/2A/ZS BG 4044211059804 100 Disconnect-blade terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3603.2 ZTRK 2,5/2A/MT BG 4044211059675 100 Basic terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3609.2 ZTRK 2,5/2A/OT BG 4044211059736 100 Creation date 17.12.2023 09:03:42 Subject to technical changes 4
3796.1 价格&库存
很抱歉,暂时无法提供与“3796.1”相匹配的价格&库存,您可以联系我们找货
    • 20+8.2436720+1.03417
