Data sheet
3796.5 ZAPT 2,5/2A BU
End plate, Width: 1.5 mm, Colour: Blue
RAL: Ähnlich 5005
Business data
Article number
3796.5
Article name
ZAPT 2,5/2A BU
GTIN (EAN)
4044211108151
Packaging unit
Quantity unit
PC
Weight per piece (not including packaging)
2.4 g
Weight per piece (including packaging)
2.51 g
Unit of weight
G
Customs number
85389099
Country of origin
DE
Prio-Article
3796.2
Product description
End plate
Creation date 17.12.2023 09:01:25
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
68 mm
Width
1.5 mm
Height
31.2 mm
Materials
Material
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Designed as end plate
Snap-on available
Environmental Product Compliance
REACH Candidate Substance Note
No
2
Data sheet
Media
3
Data sheet
Accessories
##INVERSE##CONTA-CONNECT
Fuse-disconnect terminal, Tension-spring connection, Mounting type: Mounting rail TS
35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3616.2
ZTRK 2,5/2A/ZS BG
4044211059804
100
Disconnect-blade terminal, Tension-spring connection, Mounting type: Mounting rail TS
Article number
Article name
GTIN (EAN)
Packaging
unit
3603.2
ZTRK 2,5/2A/MT BG
4044211059675
100
Basic terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated
Article number
Article name
GTIN (EAN)
Packaging
unit
3609.2
ZTRK 2,5/2A/OT BG
4044211059736
100
4
很抱歉,暂时无法提供与“3796.5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 20+8.2436720+1.03417
