3798.9
3798.9
    CONTA-CLIP
    END PLATE
3798.9 数据手册
Data sheet 3798.9 ZAPT 2,5/4A RD End plate, Width: 1.5 mm, Colour: Red Business data Article number 3798.9 Article name ZAPT 2,5/4A RD GTIN (EAN) 4044211108281 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 3g Weight per piece (including packaging) 3.11 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3798.2 Product description End plate Creation date 17.12.2023 09:02:43 Subject to technical changes 1 Data sheet 3798.9 ZAPT 2,5/4A RD Technical data Dimensions Length 92.4 mm Width 1.5 mm Height 31.2 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 09:02:43 No Subject to technical changes 2 Data sheet 3798.9 ZAPT 2,5/4A RD Media Creation date 17.12.2023 09:02:43 Subject to technical changes 3 Data sheet 3798.9 ZAPT 2,5/4A RD Accessories ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3626.2 ZTRK 2,5/4A/ZS BG 4044211059903 100 Disconnect-blade terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3605.2 ZTRK 2,5/4A/MT BG 4044211059699 100 Basic terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3611.2 ZTRK 2,5/4A/OT BG 4044211059750 100 Creation date 17.12.2023 09:02:43 Subject to technical changes 4
3798.9 价格&库存
很抱歉,暂时无法提供与“3798.9”相匹配的价格&库存,您可以联系我们找货
