3799.9
3799.9
    CONTA-CLIP
    END PLATE
3799.9 数据手册
Data sheet 3799.9 ZAP 16/2A RD End plate, Width: 2 mm, Colour: Red Business data Article number 3799.9 Article name ZAP 16/2A RD GTIN (EAN) 4044211107994 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 4.4 g Weight per piece (including packaging) 4.52 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3799.2 Product description End plate Creation date 17.12.2023 09:03:21 Subject to technical changes 1 Data sheet 3799.9 ZAP 16/2A RD Technical data Dimensions Length 81.5 mm Width 2 mm Height 43.7 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 09:03:21 No Subject to technical changes 2 Data sheet 3799.9 ZAP 16/2A RD Media Creation date 17.12.2023 09:03:21 Subject to technical changes 3 Data sheet 3799.9 ZAP 16/2A RD Accessories ##INVERSE##CONTA-CONNECT Ex protective-earth terminal ATEX-certified Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 12.1 mm, Colour: Greenyellow Article number Article name GTIN (EAN) Packaging unit 1727.2 ZSL 16/2A Ex GNYE 4044211080174 50 ST Protective earth terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 12.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3637.2 ZSL 16/2A GNYE 4044211152147 50 ST Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 12.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3636.2 ZRK 16/2A BG 4044211152130 50 Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 12.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1721.2 ZRK 16/2A Ex BG 4044211080143 50 Creation date 17.12.2023 09:03:21 Subject to technical changes 4
3799.9 价格&库存
很抱歉,暂时无法提供与“3799.9”相匹配的价格&库存,您可以联系我们找货
