3800.8
3800.8
    CONTA-CLIP
    INSULATED CROSS CONNECTOR
3800.8 数据手册
Data sheet 3800.8 ZQI 16/2 YE Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 20.4 mm, Rated cross-section: 16 mm², Colour: Yellow RAL: 1026 Business data Article number 3800.8 Article name ZQI 16/2 YE GTIN (EAN) 4044211080181 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 10.8 g Weight per piece (including packaging) 10.92 g Unit of weight G Customs number 85389099 Country of origin CZ Product description Insulated cross-connector Colour Yellow Creation date 14.12.2023 21:43:09 Subject to technical changes 1 Data sheet 3800.8 ZQI 16/2 YE Technical data Dimensions Length 7 mm Width 20.4 mm Pitch size 12 mm Ratings Voltage with partition, max. 1000 V Voltage without partition, max. 1000 V Rated current 75 A Rated cross-section 16 mm² Contamination degree 3 Connection data No. of poles 2 Materials Material Bronze Surface Tin-lead Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Plug in Insulation available Touch protection is available Number of bridged terminals 2 Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 14.12.2023 21:43:09 Subject to technical changes 2 Data sheet 3800.8 ZQI 16/2 YE Media Creation date 14.12.2023 21:43:09 Subject to technical changes 3 Data sheet 3800.8 ZQI 16/2 YE Accessories ##INVERSE##CONTA-CONNECT Feed-through terminal, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 12.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3636.2 ZRK 16/2A BG 4044211152130 50 Ex feed-through terminal ATEX-certified, Tension-spring connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 16 mm², Width: 12.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1721.2 ZRK 16/2A Ex BG 4044211080143 50 Creation date 14.12.2023 21:43:09 Subject to technical changes 4
3800.8 价格&库存
很抱歉,暂时无法提供与“3800.8”相匹配的价格&库存,您可以联系我们找货
