3992.8
3992.8
    CONTA-CLIP
    INSULATED EXTERNAL CROSS CONNECT
3992.8 数据手册
Data sheet 3992.8 AQI 3/10/18 YE External insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 28.2 mm, Rated current: 57 A; Colour: Yellow RAL: 1026 Business data Article number 3992.8 Article name AQI 3/10/18 YE GTIN (EAN) 4044211130404 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 4.4 g Weight per piece (including packaging) 4.44 g Unit of weight G Customs number 85389099 Country of origin DE Product description External insulated cross-connector Colour Yellow Creation date 15.12.2023 06:18:09 Subject to technical changes 1 Data sheet 3992.8 AQI 3/10/18 YE Technical data Dimensions Width 28.2 mm Pitch size 10 mm Ratings Rated current 57 A Contamination degree 3 Connection data No. of poles 3 Materials Material Copper Surface Tin-plated Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Further technical data Mounting type Plug in Insulation available Touch protection is available Number of bridged terminals 3 Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 06:18:09 Subject to technical changes 2 Data sheet 3992.8 AQI 3/10/18 YE Media Creation date 15.12.2023 06:18:09 Subject to technical changes 3 Data sheet 3992.8 AQI 3/10/18 YE Accessories ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1108.2 SIK 10/Z/LED(RD)/12V DC/24V AC BG 4044211017118 25 ST Fused terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 10 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17365.4 SIK 10/Z PA-G BK 4044211178390 25 ST Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1110.2 SIK 10/Z/LED(RD)/40-60V DC/80-120V AC BG 4044211017439 25 ST Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1111.2 SIK 10/Z/LED(RD)/115V DC/230V AC BG 4044211017446 25 ST Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1109.2 SIK 10/Z/LED(RD)/20-30V DC/40-60V AC BG 4044211017323 25 ST Fused terminal with disconnect plug, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17043.2 SIK 10/Z/ST BG 4044211155810 25 ST Creation date 15.12.2023 06:18:09 Subject to technical changes 4 Data sheet 3992.8 AQI 3/10/18 YE ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1112.2 SIK 10/Z/2 LED´s(RD)/24V DC BG 4044211017477 25 ST Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 10 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1102.2 SIK 10/Z BG 4044211016395 25 ST Fused terminal with disconnect plug, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 10 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17041.4 SIK 10/Z/ST PA-G BK 4044211155780 25 ST Creation date 15.12.2023 06:18:09 Subject to technical changes 5
3992.8 价格&库存
很抱歉,暂时无法提供与“3992.8”相匹配的价格&库存,您可以联系我们找货
  • 50+15.6014850+2.02067
