Data sheet
3994.8 AQI 10/10/18 YE
External insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 98.9 mm, Rated current:
57 A; Colour: Yellow
RAL: 1026
Business data
Article number
3994.8
Article name
AQI 10/10/18 YE
GTIN (EAN)
4044211130428
Packaging unit
10
Quantity unit
PC
Weight per piece (not including packaging)
15.2 g
Weight per piece (including packaging)
15.4 g
Unit of weight
G
Customs number
85389099
Country of origin
DE
Product description
Colour
Yellow
Creation date 15.12.2023 06:18:11
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Width
98.9 mm
Pitch size
10 mm
Ratings
Rated current
57 A
Contamination degree
3
Connection data
No. of poles
10
Materials
Material
Copper
Surface
Tin-plated
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-40 °C
Working temperature, max.
120 °C
Further technical data
Mounting type
Plug in
Insulation available
Touch protection is available
Number of bridged terminals
10
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
2
Data sheet
Media
3
Data sheet
Accessories
##INVERSE##CONTA-CONNECT
Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and
TS 32, Rated cross-section: 10 mm², Width: 10 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
1108.2
SIK 10/Z/LED(RD)/12V DC/24V AC BG
4044211017118
25 ST
Fused terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32,
Rated cross-section: 10 mm², Width: 10 mm, Colour: Black
Article number
Article name
GTIN (EAN)
Packaging
unit
17365.4
SIK 10/Z PA-G BK
4044211178390
25 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
1110.2
SIK 10/Z/LED(RD)/40-60V DC/80-120V AC BG
4044211017439
25 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
1111.2
SIK 10/Z/LED(RD)/115V DC/230V AC BG
4044211017446
25 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
1109.2
SIK 10/Z/LED(RD)/20-30V DC/40-60V AC BG
4044211017323
25 ST
Fused terminal with disconnect plug, Screw connection, Mounting type:Mounting rail TS
35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 10 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
17043.2
SIK 10/Z/ST BG
4044211155810
25 ST
4
Data sheet
Article number
Article name
GTIN (EAN)
Packaging
unit
1112.2
SIK 10/Z/2 LED´s(RD)/24V DC BG
4044211017477
25 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
1102.2
SIK 10/Z BG
4044211016395
25 ST
35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 10 mm, Colour: Black
Article number
Article name
GTIN (EAN)
Packaging
unit
17041.4
SIK 10/Z/ST PA-G BK
4044211155780
25 ST
5
