4856.7
4856.7
    CONTA-CLIP
    TERMINAL MARKER/POCKET-MAXICARD
4856.7 数据手册
Data sheet 4856.7 PMC SB 4/50 FW X1-X10 WH Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 4 mm, Colour: White, Print: Sequential X1-X10, Direction of print: horizontal RAL: 9010 Business data Article number 4856.7 Article name PMC SB 4/50 FW X1-X10 WH GTIN (EAN) 4044211112486 Packaging unit 500 Quantity unit PC Number of markers per card 50 ST Number of markers per row 10 ST Weight per piece (not including packaging) 0.07 g Weight per piece (including packaging) 0.1 g Unit of weight G Customs number 49119900 Country of origin DE Product description Terminal marker / Pocket Maxicard Colour White Creation date 15.12.2023 09:12:31 Subject to technical changes 1 Data sheet 4856.7 PMC SB 4/50 FW X1-X10 WH Technical data Dimensions Length 5 mm Width 4 mm Terminal width ≥ 4,10 mm Materials Marker material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Halogen-free Print Printing process Thermal transfer Number of characters, horizontal 2 Rows when using font size 1.6 and plotter pen 0.25, horizontally aligned text 2 Number of characters, vertical 3 Rows when using font size 1.6 and plotter pen 0.25, vertically aligned text 1 Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 09:12:31 Subject to technical changes 2 Data sheet 4856.7 PMC SB 4/50 FW X1-X10 WH Media Creation date 15.12.2023 09:12:31 Subject to technical changes 3 Data sheet 4856.7 PMC SB 4/50 FW X1-X10 WH Accessories Labelling pen Labelling pen for manual writing, Water resistant and smudge-proof, Line width 0.4 mm, Ink colour: Black Article number Article name GTIN (EAN) Packaging unit 2034.0 BS-1 4044211048365 10 ST Plotter Plotter marking system Article number Article name GTIN (EAN) Packaging unit 1610.0 EMS-3 Easy-Marking-System DIN A3 4044211103187 1 ST Creation date 15.12.2023 09:12:31 Subject to technical changes 4
4856.7
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种通用型晶体管输出光耦器件,具有较高的输入电流驱动能力和较快的响应速度。
3. 引脚分配:EL817共有6个引脚,其中1脚为发光二极管的阳极,2脚为阴极,3脚为集电极,4脚为发射极,5脚为集电极,6脚为发射极。
4. 参数特性:主要参数包括输入电流为50mA,输出电流为10mA,响应时间为10us。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于需要电气隔离的场合。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:EL817采用DIP-6封装形式。
4856.7 价格&库存
很抱歉,暂时无法提供与“4856.7”相匹配的价格&库存,您可以联系我们找货
  • 500+0.78286500+0.09821
