4874.7
4874.7
    CONTA-CLIP
    TERMINAL MARKER/POCKET-MAXICARD
4874.7 数据手册
Data sheet 4874.7 PMC SB 4/50 FS 251-300 WH Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 4 mm, Colour: White, Print: Sequential 251-300, Direction of print: vertical RAL: 9010 Business data Article number 4874.7 Article name PMC SB 4/50 FS 251-300 WH GTIN (EAN) 4044211112677 Packaging unit 500 Quantity unit PC Number of markers per card 50 ST Number of markers per row 10 ST Weight per piece (not including packaging) 0.07 g Weight per piece (including packaging) 0.1 g Unit of weight G Customs number 49119900 Country of origin DE Product description Terminal marker / Pocket Maxicard Colour White Creation date 15.12.2023 09:16:02 Subject to technical changes 1 Data sheet 4874.7 PMC SB 4/50 FS 251-300 WH Technical data Dimensions Length 5 mm Width 4 mm Terminal width ≥ 4,10 mm Materials Marker material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Halogen-free Print Printing process Thermal transfer Number of characters, horizontal 2 Rows when using font size 1.6 and plotter pen 0.25, horizontally aligned text 2 Number of characters, vertical 3 Rows when using font size 1.6 and plotter pen 0.25, vertically aligned text 1 Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 09:16:02 Subject to technical changes 2 Data sheet 4874.7 PMC SB 4/50 FS 251-300 WH Media Creation date 15.12.2023 09:16:02 Subject to technical changes 3 Data sheet 4874.7 PMC SB 4/50 FS 251-300 WH Accessories Labelling pen Labelling pen for manual writing, Water resistant and smudge-proof, Line width 0.4 mm, Ink colour: Black Article number Article name GTIN (EAN) Packaging unit 2034.0 BS-1 4044211048365 10 ST Plotter Plotter marking system Article number Article name GTIN (EAN) Packaging unit 1610.0 EMS-3 Easy-Marking-System DIN A3 4044211103187 1 ST Creation date 15.12.2023 09:16:02 Subject to technical changes 4
4874.7
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚集电极,5脚发射极,6脚地。
4. 参数特性:工作温度范围为-40至85摄氏度,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有抗干扰能力强,响应速度快等特点。
6. 应用信息:广泛应用于工业控制、医疗设备等领域。
7. 封装信息:采用DIP6封装。
4874.7 价格&库存
很抱歉,暂时无法提供与“4874.7”相匹配的价格&库存,您可以联系我们找货
