5710.2
5710.2
    CONTA-CLIP
    LAMP TEST MODULE
5710.2 数据手册
Data sheet 5710.2 LPM 7-A Lamp test module, With 7 channels, Common cathode with common collection point, Diode type 1N 4007, Screw connection, Mounting type: Mounting rail TS 35 Business data Article number 5710.2 Article name LPM 7-A GTIN (EAN) 4044211069148 Packaging unit 1 Quantity unit PC Weight per piece (not including packaging) 78 g Weight per piece (including packaging) 106.5 g Unit of weight G Customs number 85411000 Country of origin NL Prio-Article 5710.2 Product description Lamp test module Accessories Without cover Creation date 15.12.2023 11:43:56 Subject to technical changes 1 Data sheet 5710.2 LPM 7-A Technical data Dimensions Length 87 mm Width 49 mm Height TS 35/7.5 57 mm Ratings Overvoltage category III Contamination degree 2 Connection data Connection principle Screw connection Wire cross-section single core (rigid), min. 0.2 mm² Wire cross-section single-core (rigid), max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Stripping length 7 mm Torque 0.6 Nm Input data Max. operating voltage AC/DC 250 V Current load per channel, max. 1A Number of channels 7 Shared anode 1 Materials Working temperature, min. -20 °C Working temperature, max. 50 °C Environmental Product Compliance REACH Candidate Substance Note Creation date 15.12.2023 11:43:56 No Subject to technical changes 2 Data sheet 5710.2 LPM 7-A Approvals Standards and regulations Standards / specifications Creation date 15.12.2023 11:43:56 DIN VDE 0110 / EN 50178 Subject to technical changes 3 Data sheet 5710.2 LPM 7-A Media Creation date 15.12.2023 11:43:56 Subject to technical changes 4 Data sheet 5710.2 LPM 7-A Accessories Creation date 15.12.2023 11:43:56 Subject to technical changes 5
5710.2 价格&库存
很抱歉,暂时无法提供与“5710.2”相匹配的价格&库存,您可以联系我们找货
