6176.2
6176.2
    CONTA-CLIP
    RELAY MODULE
6176.2 数据手册
Data sheet 6176.2 RIMD16/2W/24V- Multiple relay module, Screw connection, With 16 miniature relays, 2 CO contacts each, Soldered, With illuminated display, Minus switching, Input voltage: 24 VDC Business data Article number 6176.2 Article name RIMD16/2W/24V- GTIN (EAN) 4044211072605 Packaging unit 1 Quantity unit PC Weight per piece (not including packaging) 690 g Weight per piece (including packaging) 829 g Unit of weight G Customs number 85364900 Country of origin NL Product description Relay module Creation date 15.12.2023 12:41:14 Subject to technical changes 1 Data sheet 6176.2 RIMD16/2W/24VTechnical data Dimensions Length 87 mm Width 293 mm Height 72 mm Ratings Overvoltage category III Contamination degree 2 Connection data Connection principle Screw connection Wire cross-section single core (rigid), min. 0.08 mm² Wire cross-section single-core (rigid), max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Stripping length 7 mm Torque 0.6 Nm Input data Input voltage 24 VDC Number of channels 16 Power consumption 0.5 W reverse-polarity protection diode 1 Minus switching (sync) 1 Output data Switching voltage / switching voltage max. 250 / 250 VAC Continuous current max. / Inrush current max. 4/8A Contact configuration 2 CO contacts Switching capacity, max. 1250 VA Electrical lifespan (AC1) 20x10⁴ Mechanical lifespan 10x10⁶ Creation date 15.12.2023 12:41:14 Subject to technical changes 2 Data sheet 6176.2 RIMD16/2W/24VTechnical data Materials Contact material AgNi 90/10 Working temperature, min. -20 °C Working temperature, max. 55 °C Further technical data Protection class IP20 Insulation voltage coil/contact 4 kV Status display red Free-wheel diode Response/release time 9 / 7 ms Pinning 5 mm Operating voltage indicator LED Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 12:41:14 Subject to technical changes 3 Data sheet 6176.2 RIMD16/2W/24VApprovals Standards and regulations CE compliant yes Standards / specifications DIN VDE 0110 / EN 50178 Creation date 15.12.2023 12:41:14 Subject to technical changes 4 Data sheet 6176.2 RIMD16/2W/24VMedia Creation date 15.12.2023 12:41:14 Subject to technical changes 5 Data sheet 6176.2 RIMD16/2W/24VAccessories Creation date 15.12.2023 12:41:14 Subject to technical changes 6
6176.2 价格&库存
很抱歉,暂时无法提供与“6176.2”相匹配的价格&库存,您可以联系我们找货
