Data sheet
6600.2 RIM16S/1W/24V+
Multiple relay module with manual actuation, Screw connection, With 16 miniature relays, 1 CO contact each,
Plugged in, With illuminated display, Positive switching, Input voltage: 24 VDC
Business data
Article number
6600.2
Article name
RIM16S/1W/24V+
GTIN (EAN)
4044211075057
Packaging unit
1
Quantity unit
PC
Weight per piece (not including packaging)
661.8 g
Weight per piece (including packaging)
782.7 g
Unit of weight
G
Customs number
85364900
Country of origin
NL
Product description
Relay module
Creation date 15.12.2023 09:00:13
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
87 mm
Width
292 mm
Height
74 mm
Ratings
Overvoltage category
III
Contamination degree
2
Connection data
Connection principle
Screw connection
Wire cross-section single core (rigid), min.
0.08 mm²
Wire cross-section single-core (rigid), max.
4 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
2.5 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.2 mm²
max.
2.5 mm²
Stripping length
7 mm
Torque
0.6 Nm
Input data
Input voltage
24 VDC
Number of channels
16
Plus switching (source)
1
Power consumption
0,6 W
reverse-polarity protection diode
1
Output data
Switching voltage / switching voltage max.
250 / 250 VAC
Continuous current max. / Inrush current max.
6 / 10 A
Contact configuration
1 CO contact
Switching capacity, max.
2000 VA
Electrical lifespan (AC1)
1,5x10⁵
Mechanical lifespan
10x10⁶
2
Data sheet
Technical data
Materials
Contact material
AgNi 90/10
Working temperature, min.
-20 °C
Working temperature, max.
55 °C
Further technical data
Protection class
IP20
Insulation voltage coil/contact
4 kV
Status display red
Free-wheel diode
Response/release time
9 / 7 ms
Pinning
3.5 mm
Manual/Off/Automatic switching
Operating voltage indicator LED
Pluggable relay
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
3
Data sheet
Approvals
Standards and regulations
CE compliant
yes
Standards / specifications
DIN VDE 0110 / EN 50178
4
Data sheet
Media
5
Data sheet
Accessories
6
很抱歉,暂时无法提供与“6600.2”相匹配的价格&库存,您可以联系我们找货
