7788.2
7788.2
    CONTA-CLIP
    SOLD-STATE OUTPUT MODULE
7788.2 数据手册
Data sheet 7788.2 SSOIF 16+ Multiple solid-state output modules for G4 SSR relays, Screw connection, Mounting type: Mounting rail TS 35, 16 channels, Positive switching, Delivered without SSR relay Business data Article number 7788.2 Article name SSOIF 16+ GTIN (EAN) 4044211078065 Packaging unit 1 Quantity unit PC Weight per piece (not including packaging) 269.9 g Weight per piece (including packaging) 375.3 g Unit of weight G Customs number 85365003 Country of origin NL Product description Solid-state output module Creation date 15.12.2023 15:28:34 Subject to technical changes 1 Data sheet 7788.2 SSOIF 16+ Technical data Dimensions Length 87 mm Width 212 mm Height 57 mm Ratings Overvoltage category III Contamination degree 2 Connection data Connection principle Screw connection Wire cross-section single core (rigid), min. 0.2 mm² Wire cross-section single-core (rigid), max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Stripping length 7 mm Torque 0.6 Nm Input data Number of channels 16 Materials Working temperature, min. -20 °C Working temperature, max. 55 °C Further technical data Remarks + schaltend Test voltage 4 kV Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 15:28:34 Subject to technical changes 2 Data sheet 7788.2 SSOIF 16+ Approvals Standards and regulations Standards / specifications Creation date 15.12.2023 15:28:34 DIN VDE 0110 / EN 50178 Subject to technical changes 3 Data sheet 7788.2 SSOIF 16+ Media Creation date 15.12.2023 15:28:34 Subject to technical changes 4 Data sheet 7788.2 SSOIF 16+ Accessories Creation date 15.12.2023 15:28:34 Subject to technical changes 5
7788.2 价格&库存
很抱歉,暂时无法提供与“7788.2”相匹配的价格&库存,您可以联系我们找货
