Data sheet
7791.2 DC-DC/5-0,5
DC/DC converter module, regulated, Screw connection, Mounting type: Mounting rail TS 35, Input: 1-phase,
Output: 5 VDC/0.5 A
Business data
Article number
7791.2
Article name
DC-DC/5-0,5
GTIN (EAN)
4044211078096
Packaging unit
1
Quantity unit
PC
Weight per piece (not including packaging)
37.7 g
Weight per piece (including packaging)
79.5 g
Unit of weight
G
Customs number
85423990
Country of origin
NL
Product description
Converter module
Creation date 17.12.2023 09:06:20
Subject to technical changes
1
Data sheet
7791.2 DC-DC/5-0,5
Technical data
Dimensions
Length
18 mm
Width
87 mm
Height TS 35/7.5
57 mm
Ratings
Overvoltage category
III
Contamination degree
2
Connection data
Connection principle
Screw connection
Wire cross-section single core (rigid), min.
0.2 mm²
Wire cross-section single-core (rigid), max.
4 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
2.5 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.2 mm²
max.
2.5 mm²
Stripping length
7 mm
Torque
0.6 Nm
Input data
Input voltage DC min.
7,5 V
Input voltage DC max.
40 V
Zero-load current
5 mA
Power consumption
2,5 W
Output data
Output voltage DC
5V
Regulated DC voltage
Output current
0.5 A
Short-circuit current
0,9 A
Residual ripple
很抱歉,暂时无法提供与“7791.2”相匹配的价格&库存,您可以联系我们找货
