7888.2
7888.2
    CONTA-CLIP
    TIMER RELAY
7888.2 数据手册
Data sheet 7888.2 EG-ZME/24VACDC 3-30s On-delay timing relay, time range: 3 s to 30 s, Screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Supply voltage: 24 VAC/DC Business data Article number 7888.2 Article name EG-ZME/24VACDC 3-30s GTIN (EAN) 4044211078232 Packaging unit 1 Quantity unit PC Weight per piece (not including packaging) 64 g Weight per piece (including packaging) 74.59 g Unit of weight G Customs number 85364900 Country of origin NL Product description Timing relay Creation date 17.12.2023 09:06:30 Subject to technical changes 1 Data sheet 7888.2 EG-ZME/24VACDC 3-30s Technical data Dimensions Length 78 mm Width 22.5 mm Height TS 35 / 7.5 with BA 84 mm Ratings Overvoltage category III Contamination degree 2 Connection data Connection principle Screw connection Wire cross-section single core (rigid), min. 0.2 mm² Wire cross-section single-core (rigid), max. 2.5 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Stripping length 7 mm Input data Power supply AC/DC 24 V Output data Relay contact 1 CO contact Materials Working temperature, max. 50 °C Further technical data Protection class IP20 Status display Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 17.12.2023 09:06:30 Subject to technical changes 2 Data sheet 7888.2 EG-ZME/24VACDC 3-30s Media Creation date 17.12.2023 09:06:30 Subject to technical changes 3 Data sheet 7888.2 EG-ZME/24VACDC 3-30s Accessories Creation date 17.12.2023 09:06:30 Subject to technical changes 4
7888.2 价格&库存
很抱歉,暂时无法提供与“7888.2”相匹配的价格&库存,您可以联系我们找货
