9106.7
9106.7
    CONTA-CLIP
    TERMINAL MARKER/POCKET-MAXICARD
9106.7 数据手册
Data sheet 9106.7 PMC BSTR 6/30 WH Terminal marker / Pocket Maxicard, Length: 12 mm, Width: 6 mm, Colour: White RAL: 9010 Business data Article number 9106.7 Article name PMC BSTR 6/30 WH GTIN (EAN) 4044211099732 Packaging unit 300 Quantity unit PC Number of markers per card 30 ST Number of markers per row 10 ST Weight per piece (not including packaging) 0.1 g Weight per piece (including packaging) 0.14 g Unit of weight G Customs number 39269097 Country of origin DE Product description Terminal marker / Pocket Maxicard Colour White Creation date 15.12.2023 20:14:39 Subject to technical changes 1 Data sheet 9106.7 PMC BSTR 6/30 WH Technical data Dimensions Length 12 mm Width 6 mm Terminal width ≥ 5,10 mm Materials Marker material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Halogen-free Print Printing process Thermal transfer Number of characters, horizontal 3 Rows when using font size 1.6 and plotter pen 0.25, horizontally aligned text 3 Number of characters, vertical 8 Rows when using font size 1.6 and plotter pen 0.25, vertically aligned text 3 Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 20:14:39 Subject to technical changes 2 Data sheet 9106.7 PMC BSTR 6/30 WH Media Creation date 15.12.2023 20:14:39 Subject to technical changes 3 Data sheet 9106.7 PMC BSTR 6/30 WH Accessories Labelling pen Labelling pen for manual writing, Water resistant and smudge-proof, Line width 0.4 mm, Ink colour: Black Article number Article name GTIN (EAN) Packaging unit 2034.0 BS-1 4044211048365 10 ST Plotter Plotter marking system Article number Article name GTIN (EAN) Packaging unit 1610.0 EMS-3 Easy-Marking-System DIN A3 4044211103187 1 ST ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 220 to 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15493.2 ZPRC 220...240V AC/DC 4044211118334 10 ST Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VDC Article number Article name GTIN (EAN) Packaging unit 15494.2 ZPRC 6-12-24V DC 4044211118341 10 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection and residual current suppression for long cables, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15555.2 PRC LW 110...125V AC/DC 4044211118280 10 ST Creation date 15.12.2023 20:14:39 Subject to technical changes 4 Data sheet 9106.7 PMC BSTR 6/30 WH ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection and residual current suppression for long cables, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15556.2 ZPRC LW 110...125V AC/DC 4044211118358 10 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 230 to 240 VAC Article number Article name GTIN (EAN) Packaging unit 16145.2 PRC 230...240V AC 4044211189532 10 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6.12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15488.2 PRC 6-12-24V AC/DC 4044211118228 10 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 220 to 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15489.2 PRC 220...240V AC/DC 4044211118259 10 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VDC Article number Article name GTIN (EAN) Packaging unit 15490.2 PRC 6-12-24V DC 4044211118266 10 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection and residual current suppression for long cables, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 220 to 240 VAC Article number Article name GTIN (EAN) Packaging unit 15491.2 PRC LW 220...240V AC 4044211118273 10 ST Creation date 15.12.2023 20:14:39 Subject to technical changes 5 Data sheet 9106.7 PMC BSTR 6/30 WH ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15492.2 ZPRC 6-12-24V AC/DC 4044211118297 10 ST Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection and residual current suppression for long cables, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 220 to 240 VAC Article number Article name GTIN (EAN) Packaging unit 15495.2 ZPRC LW 220...240V AC 4044211118365 10 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 48 or 60 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15496.2 PRC 48-60V AC/DC 4044211118235 10 ST Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15497.2 PRC 110...125V AC/DC 4044211118242 10 ST Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 648 or 60 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15498.2 ZPRC 48-60V AC/DC 4044211118303 10 ST Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 110 to 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15499.2 ZPRC 110...125V AC/DC 4044211118327 10 ST Creation date 15.12.2023 20:14:39 Subject to technical changes 6 Data sheet 9106.7 PMC BSTR 6/30 WH ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 60 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15510.2 PRCU 1/60V AC/DC 4044211118495 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 48 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15520.2 ZPRCU 1/48V AC/DC 4044211118594 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with tension-spring connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15552.2 ZPRCU LW 1/240V AC 4044211118679 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15511.2 PRCU 1/125V AC/DC 4044211118501 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15512.2 PRCU 1/240V AC/DC 4044211118518 10 ST Creation date 15.12.2023 20:14:39 Subject to technical changes 7 Data sheet 9106.7 PMC BSTR 6/30 WH ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 12 VDC Article number Article name GTIN (EAN) Packaging unit 15514.2 PRCU 1/12V DC 4044211118532 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with tension-spring connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 12 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15518.2 ZPRCU 1/12V AC/DC 4044211118570 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15519.2 ZPRCU 1/24V AC/DC 4044211118587 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 60 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15521.2 ZPRCU 1/60V AC/DC 4044211118600 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 12 VDC Article number Article name GTIN (EAN) Packaging unit 15525.2 ZPRCU 1/12V DC 4044211118648 10 ST Creation date 15.12.2023 20:14:39 Subject to technical changes 8 Data sheet 9106.7 PMC BSTR 6/30 WH ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 15526.2 ZPRCU 1/24V DC 4044211118655 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with tension-spring connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15551.2 ZPRCU LW 1/125V AC/DC 4044211118662 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15508.2 PRCU 1/24V AC/DC 4044211118471 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 48 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15509.2 PRCU 1/48V AC/DC 4044211118488 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6 VDC Article number Article name GTIN (EAN) Packaging unit 15513.2 PRCU 1/6V DC 4044211118525 10 ST Creation date 15.12.2023 20:14:39 Subject to technical changes 9 Data sheet 9106.7 PMC BSTR 6/30 WH ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15523.2 ZPRCU 1/240V AC/DC 4044211118624 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6 VDC Article number Article name GTIN (EAN) Packaging unit 15524.2 ZPRCU 1/6V DC 4044211118631 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15553.2 PRCU LW 1/125V AC/DC 4044211118556 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with multi-layer gold contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 16128.2 PRCU 1/24V DC Au 4044211178635 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with tension-spring connection and pluggable miniature relay PRC... with multi-layer gold contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 16129.2 ZPRCU 1/24V DC Au 4044211178659 10 ST Creation date 15.12.2023 20:14:39 Subject to technical changes 10 Data sheet 9106.7 PMC BSTR 6/30 WH ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 24 VDC Article number Article name GTIN (EAN) Packaging unit 15515.2 PRCU 1/24V DC 4044211118549 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 125 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15522.2 ZPRCU 1/125V AC/DC 4044211118617 10 ST Plug-Relay-Compact (PRC) Complete, Consisting of base PRC... with screw connection and pluggable miniature relay PRC... with power contact, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 240 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15554.2 PRCU LW 1/240V AC 4044211118563 10 ST ##INVERSE##CONTA-ELECTRONICS Plug-Relay-Compact (PRC) socket base PRC with tension-spring connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 6, 12 or 24 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15492.2 ZPRC 6-12-24V AC/DC 4044211118297 10 ST ##INVERSE##CONTA-ELECTRONICS Creation date 15.12.2023 20:14:39 Subject to technical changes 11 Data sheet 9106.7 PMC BSTR 6/30 WH Plug-Relay-Compact (PRC) socket base PRC with screw connection, Mounting type: Mounting rail TS 35, 1 CO contact, Input voltage: 48 or 60 VAC/DC Article number Article name GTIN (EAN) Packaging unit 15496.2 PRC 48-60V AC/DC 4044211118235 10 ST Creation date 15.12.2023 20:14:39 Subject to technical changes 12
9106.7 价格&库存
很抱歉,暂时无法提供与“9106.7”相匹配的价格&库存,您可以联系我们找货
