9433.7
9433.7
    CONTA-CLIP
    TERMINAL MARKER/POCKET-MAXICARD
9433.7 数据手册
Data sheet 9433.7 PMC BSTR 10x12/10 WH Terminal marker / Pocket Maxicard, Length: 12 mm, Width: 10 mm, Colour: White RAL: 9010 Business data Article number 9433.7 Article name PMC BSTR 10x12/10 WH GTIN (EAN) 4044211155223 Packaging unit 100 Quantity unit PC Number of markers per card 10 ST Number of markers per row 5 ST Weight per piece (not including packaging) 0.02 g Weight per piece (including packaging) 0.06 g Unit of weight G Customs number 39269097 Country of origin DE Product description Terminal marker / Pocket Maxicard Colour White Creation date 14.12.2023 19:16:35 Subject to technical changes 1 Data sheet 9433.7 PMC BSTR 10x12/10 WH Technical data Dimensions Length 12 mm Width 10 mm Terminal width ≥ 10,00 mm Materials Marker material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Halogen-free Print Printing process Thermal transfer Number of characters, horizontal 8 Rows when using font size 1.4 and plotter pen 0.25, horizontally aligned text 5 Number of characters, vertical 9 Rows when using font size 1.4 and plotter pen 0.25, vertically aligned text 5 Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 14.12.2023 19:16:35 Subject to technical changes 2 Data sheet 9433.7 PMC BSTR 10x12/10 WH Media Creation date 14.12.2023 19:16:35 Subject to technical changes 3 Data sheet 9433.7 PMC BSTR 10x12/10 WH Accessories Labelling pen Labelling pen for manual writing, Water resistant and smudge-proof, Line width 0.4 mm, Ink colour: Black Article number Article name GTIN (EAN) Packaging unit 2034.0 BS-1 4044211048365 10 ST Plotter Plotter marking system Article number Article name GTIN (EAN) Packaging unit 1610.0 EMS-3 Easy-Marking-System DIN A3 4044211103187 1 ST ##INVERSE##CONTA-CON Feed-through terminal, Screw connection, Mounting type: Mounting surface, Rated crosssection: 10 mm², Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17387.6 SDK 10/2A/Z GR 4044211209803 50 Feed-through terminal, Screw connection, Mounting type: Mounting surface, Rated crosssection: 10 mm², Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17386.6 SDK 10/2A GR 4044211209797 50 Feed-through terminal, Screw connection, Mounting type: Mounting surface, Rated crosssection: 10 mm², Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17388.6 SDK 10/1A/1L GR 4044211209889 50 ST Creation date 14.12.2023 19:16:35 Subject to technical changes 4 Data sheet 9433.7 PMC BSTR 10x12/10 WH ##INVERSE##CONTA-CON Feed-through terminal, Screw connection, Mounting type: Mounting surface, Rated crosssection: 10 mm², Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17389.6 SDK 10/1A/1L/Z GR 4044211209896 50 ST Feed-through terminal, Screw connection, Mounting type: Mounting surface, Rated crosssection: 16 mm², Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17394.6 SDK 16/2A GR 4044211210595 50 ST Feed-through terminal, Screw connection, Mounting type: Mounting surface, Rated crosssection: 16 mm², Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17396.6 SDK 16/1A/1B GR 4044211210618 50 ST Feed-through terminal, Screw connection, Mounting type: Mounting surface, Rated crosssection: 16 mm², Colour: Grey Article number Article name GTIN (EAN) Packaging unit 17397.6 SDK 16/1A/1B/Z GR 4044211210625 50 ST Creation date 14.12.2023 19:16:35 Subject to technical changes 5
9433.7 价格&库存
很抱歉,暂时无法提供与“9433.7”相匹配的价格&库存,您可以联系我们找货
