WRL-17732
WRL-17732
    SPARKFUNELECTRONICS
    STEEDAN MA350 LOW PROFILE, 5-IN-
WRL-17732 数据手册
Steedan Part No: MA350.A.LBICG.003 Description: Steedan 5-in-1 Magnetic Mount Combination Antenna with GNSS, 2*5G/4G & 2*Wi-Fi Features: Low Profile Magnetic Mount Enclosure 2* 5G/4G MIMO 600-6000MHz 2* Wi-Fi (including Wi-Fi 6) MIMO 2.4GHz/5.8/7.1GHz 1* GPS-GLONASS-Galileo-BeiDou Antenna IP65 Rated, Ruggedized PC/ABS Enclosure LTE: 3m CFD200 Cable and SMA(M)ST Connector Wi-Fi: 3m CFD200 Cable and RP SMA(M)ST Connector GNSS: 3m RG-174 Cable and SMA(M)ST Connector Dimensions: 250 x 144.3 x 52.8mm RoHS & Reach Compliant SPE-18-8-095-C 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 9 4. Radiation Patterns 21 5. Active Antenna Characteristics 51 6. Mechanical Drawing 53 7. Packaging 54 8. Application Note 55 Changelog 72 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-18-8-095-C www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. Introduction The Taoglas Steedan MA350 is a 5-in-1 next-generation low profile magnetic mount antenna for vehicle, outdoor building and heavy equipment roof applications. It has a fully IP65 rated waterproof robust ABS enclosure and base. This is an ideal external combination antenna solution that is used where drilling a hole through the roof of a vehicle or a metal panel is not feasible. It can be mounted on steel surfaces and its ultra-strong neodymium magnets. A soft foam cushion on the base protects the mounting surface during installation and removal. Only 52.8mm high it mounts discretely to the target application out of sight of most onlookers. Introduction This outstanding antenna delivers powerful MIMO antenna technology 5G/4G and Wi-Fi (including the newly established Wi-Fi 6) 2.4/5.8/7.1GHz and a custom tuned GPS/GLONASS/BeiDou patch antenna for GNSS location services. The 5 internal antennas have superior isolation. The 5G/4G antennas also include backward compatibility to work at most worldwide 3G and 2G bands. Introduction Introduction Typical Applications: • Next Generation OEM Automotive Connectivity • Multimedia, Navigation and Telematics Systems • V2V, V2X and Fleet Management Applications • First Net Responder Routers The MA350 is ideal for applications that require highly sophisticated antennas for real-time streaming applications that demand high-speed video uplink and downlink into the cabin of the vehicle. These challenges are resolved by the highly efficient, high gain MIMO antennas, with high isolation, all of which is necessary to achieve the required signal to noise ratio and throughput. The MA350 can also be customized for your particular wireless application and frequency band, subject to NRE and MOQ. There are 5x 3000mm low loss TGC-200 cables, terminating in SMA(M) connectors for LTE MIMO, and RP SMA(M) for Wi-Fi MIMO. There is a 3000mm RG-174 cable for GNSS terminating in an SMA(M) connector. All cable lengths and connector types are customizable, for further information contact your regional Taoglas customer support team. SPE-18-8-095-C www.taoglas.com 3 2. Specifications 3. GNSS Frequency Bands Covered Antenna Characteristics2. Specifications GPS L1 L2 L5 GLONASS 3. ▓ □ G1 G2 G3 ▓ ▓ Antenna Characteristics Galileo BeiDou 4. ▓ E1 E5a E5b E6 ▓ □ ▓ □ B1 B2a B2b B3 ▓ □ ▓ □ Antenna Radiation Patterns3. Antenna QZSS (Regional) L1 Characteristics2. ▓ IRNSS (Regional) 3. □ L2C L5 L6 ▓ □ □ Specifications L5 □ Antenna Characteristics2. SBAS L1/E1/B1 L5/B2a/E5a ▓ □ ◼ GNSS Frequency Bands Covered. Specifications G1 G2 ▓ □ G3 □ □ GNSS Frequency Bands Not Covered. *SBAS systems: WASS(L1/L5), EGNOSS(E1/E5a), SDCM(G1/G2/G3), SNAS(B1,B2a), GAGAN(L1/L5), QZSS(L1/L5), KAZZ(L1/L5). 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. GNSS Bands and Constellations Antenna Radiation Patterns3.Antenna Characteristics2. SPE-18-8-095-C Specifications www.taoglas.com 4 GNSS Electrical Frequency (MHz) 1561 1575.42 1602 Return Loss (dB)
WRL-17732 价格&库存
很抱歉,暂时无法提供与“WRL-17732”相匹配的价格&库存,您可以联系我们找货
