PRT-18723
PRT-18723
    SPARKFUNELECTRONICS
    电池
    光电型 太阳能电池 330 mW 2.84 V
PRT-18723 数据手册
G Panel Width: 52 19.78 17.5 Panel Thickness 15-35 mm from Edge: 2.6 0.3 PCB Thickness: 1.5 EVA Border: 1 0.5 Front This document contains proprietary information and may not be copied or shared without the consent of Voltaic Systems 10 21 1 1 1 Panel Length: 52 PCB Width: 50 PCB Length: 50 18.17 5.72 7.33 Panel Corner and Edge: 2.3 MIN 1 V- V+ 2X 5 x 5 Solder Pads Model: P121 R1G Batch: YYYY-MM Power (Pmax): 0.33 W Voltage (Vmp): 2.43 V Current (Imp): 0.13 A Open-Circuit Voltage (Voc): 2.84 V Short-Circuit Current (Isc): 0.15 A Side Back Drawing Details Construction Power Specifications Panel Number: P121 Revision: R1G Engineer: CY Checked By: SM Date Created: 2020-01-28 Date Modified: 2020-04-10 Changes: PCB Thickness Tolerance: 0.3 Units: mm 1.5:1 Sheet: Scale: 1/1 All Materials RoHS Compliant Substrate: Black DS PCB Encapsulant: EVA F806P Top Layer: ETFE YH05 Wire Number: N/A Wire Length: N/A Strain Relief: N/A Attachment: N/A Temperature: -40 to 85 C Output Tolerance: 10% of Voltage and Current Solar Cell: SunPower Maxeon Gen III Je3A Nominal Efficiency: 4 22% Cell Pieces: Panel Electrical Ratings Nominal Expected Open-Circuit Voltage Voc 2.84 2.55 V Voltage at Max Power Vp 2.43 2.19 V Short-Circuit Current Isc 0.15 0.13 A Current at Max Power Ip 0.13 0.12 A Maximum Power Wp 0.33 0.27 W
PRT-18723 价格&库存
很抱歉,暂时无法提供与“PRT-18723”相匹配的价格&库存,您可以联系我们找货
PRT-18723
    • 1+49.24800
    • 200+19.65600
    • 500+18.99720
    • 1000+18.67320
