COM-17862
COM-17862
    SPARKFUNELECTRONICS
    可穿戴设备 电子织物 缝纫 -
COM-17862 数据手册
SIngle Pressure Sensor DATASHEET The single pressure sensor gives you an analog read that maps to force on the sensor. The more you press, the lower the resistance goes, perfect for onbody pressure related sensing like ribcage expansion for breathing. This sensor is small but mighty, making it convenient for small surface area applications. MATERIALS: INSULATION: THERMOPLASTIC POLYURETHANE INNER CONDUCTOR: PROPRIETARY INTERCONNECT : ENIG FLEX PCB PRESSURE SENSITIVE MATERIAL: PROPRIETARY PINOUT: DATA: BEND RADIUS LIMITATION: NONE THICKNESS: APPROX 20 MILS OPERATING VOLTAGE RANGE: 3.7V-5V PRESSURE RANGE: .5LBS - 10LBS COMPONENT DIMENSIONS: 2" X 1" SENSING AREA DIMENSIONS: .75" X .75" RESISTANCE VS PRESSURE GRAMS OF FORCE 150 200 250 300 350 400 450 500 6350 10,886 13,607 RESISTANCE (IN OHMS) 180,000 70,000 27,000 18,000 RECOMMENDED 15,000 OPERATING 13,000 RANGE 13,500 13,000 1,000 600 300 OPERATING NOTES: DO NOT WASH DO NOT CUT DO NOT DISASSEMBLE DO NOT SEW DO NOT EXPOSE TO TEMPERATURES ABOVE 150 DEGREES F NOT REUSABLE - STICKING AND DE-STICKING OR DESOLDERING WILL CAUSE DAMAGE FOR PROTOTYPING ONLY. ALL DATA IS APPROXIMATE AND THESE PARTS ARE NOT DESIGNED FOR PRODUCTION USE. USE CARE WHEN SOLDERING. LONG EXPOSURE TO HEAT WILL CAUSE DELAMINATION DO NOT SOLDER ON TOP OF A TEXTILE DO NOT USE AS A "LEVER" TO REMOVE THE PART FROM A BREADBOARD. IF USING WITH HEADERS, HOLD THE HEADERS TO DETACH. Our parts are produced by hand. There can be significant variation between units. Please use this data only as a reference, as your part's exact values may differ. DOUBLE BACKLIT USER INTERFACE DATASHEET The double backlit button is like the single backlit button, but twice the fun! Use this part if you need to control something up and down, or right to left. Using cut-out vinyl, you can create icons and decals on fabric that show your users the button functionalities. MATERIALS: INSULATION: THERMOPLASTIC POLYURETHANE INNER CONDUCTOR: PROPRIETARY INTERCONNECT : ENIG FLEX PCB PINOUT: DOUBLE BACKLIT USER INTERFACE BEND RADIUS LIMITATION: .5" AROUND BUTTON AREA THICKNESS: APPROX 1MM AT BUTTON OPERATING VOLTAGE RANGE: 5V COMPONENT DIMENSIONS: 4.6" X 6.3" BUTTON DIMENSIONS: 1" DIAMETER CIRCLE DURABILITY: 10,000 PRESSES UNDER 5LBF USE SUGGESTION TIP: Use a cut-out vinyl sticker or other kind of OPERATING NOTES: DO NOT WASH mask to make backlit logos from your button. DO NOT CUT DO NOT DISASSEMBLE DO NOT SEW DO NOT EXPOSE TO TEMPERATURES ABOVE 150 DEGREES F NOT REUSABLE - STICKING AND DE-STICKING OR DESOLDERING WILL CAUSE DAMAGE FOR PROTOTYPING ONLY. ALL DATA IS APPROXIMATE AND THESE PARTS ARE NOT DESIGNED FOR PRODUCTION USE. USE CARE WHEN SOLDERING. LONG EXPOSURE TO HEAT WILL CAUSE DELAMINATION DO NOT SOLDER ON TOP OF A TEXTILE Our parts are produced by hand. There can be significant variation between units. Please use this data only as a reference, as your part's exact values may differ. mini Pressure Matrix DATASHEET If you are looking to map pressure over a 1.25" area, this is the one. Our 3x3 mini pressure matrix has 6 leads, allowing you to map which point you are at in the 3x3 matrix. Each area has an analog readout that varies depending on the weight of the item on the pressure sensor. Generally, sensor values will read from 500Kohms to 100ohms depending on the force put onto the sensor. MATERIALS: INSULATION: THERMOPLASTIC POLYURETHANE INNER CONDUCTOR: PROPRIETARY INTERCONNECT : ENIG FLEX PCB PRESSURE SENSITIVE MATERIAL: PROPRIETARY PINOUT: MINI PRESSURE MATRIX BEND RADIUS LIMITATION: NONE THICKNESS: APPROX 20 MILS OPERATING VOLTAGE RANGE: 3.7V-5V PRESSURE RANGE: .2LBS - 10LBS COMPONENT DIMENSIONS: 2.3" X 3" SENSING AREA DIMENSIONS: 1.25" X 1.25" RESISTANCE VS PRESSURE FOR EACH MATRIX SQUARE GRAMS OF FORCE 150 200 250 300 350 400 450 500 6350 10,886 13,607 RESISTANCE (IN OHMS) 180,000 70,000 27,000 18,000 RECOMMENDED 15,000 OPERATING 13,000 RANGE 13,500 13,000 1,000 600 300 OPERATING NOTES: DO NOT WASH DO NOT CUT DO NOT DISASSEMBLE DO NOT SEW DO NOT EXPOSE TO TEMPERATURES ABOVE 150 DEGREES F NOT REUSABLE - STICKING AND DE-STICKING OR DESOLDERING WILL CAUSE DAMAGE FOR PROTOTYPING ONLY. ALL DATA IS APPROXIMATE AND THESE PARTS ARE NOT DESIGNED FOR PRODUCTION USE. USE CARE WHEN SOLDERING. LONG EXPOSURE TO HEAT WILL CAUSE DELAMINATION DO NOT SOLDER ON TOP OF A TEXTILE Our parts are produced by hand. There can be significant variation between units. Please use this data only as a reference, as your part's exact values may differ. BUSES DATASHEET MATERIALS: INSULATION: THERMOPLASTIC POLYURETHANE INNER CONDUCTOR: PROPRIETARY METAL INTERCONNECT : ENIG FLEX PCB OPERATING NOTES: DO NOT WASH DO NOT CUT DO NOT DISASSEMBLE DO NOT SEW DO NOT EXPOSE TO TEMPERATURES ABOVE 150 DEGREES F NOT REUSABLE - STICKING AND DE-STICKING OR DESOLDERING WILL CAUSE DAMAGE FOR PROTOTYPING ONLY. ALL DATA IS APPROXIMATE AND THESE PARTS ARE NOT DESIGNED FOR PRODUCTION USE. USE CARE WHEN SOLDERING. LONG EXPOSURE TO HEAT WILL CAUSE DELAMINATION DO NOT SOLDER ON TOP OF A TEXTILE Our parts are produced by hand. There can be significant variation between units. Please use this data only as a reference, as your part's exact values may differ. S-CURVE BUS BEND RADIUS LIMITATION: NONE THICKNESS: APPROX. 10 MILS MAX CURRENT PER TRACE: 1A COMPONENT DIMENSIONS: 4" X 6" RESISTANCE PER TRACE: < 1 OHM C-CURVE BUS BEND RADIUS LIMITATION: NONE THICKNESS: APPROX. 10 MILS MAX CURRENT PER TRACE: 1A COMPONENT DIMENSIONS: 4" X 3" RESISTANCE PER TRACE: < 1 OHM 4-WIRE BUS BEND RADIUS LIMITATION: NONE THICKNESS: APPROX. 10 MILS MAX CURRENT PER TRACE: 1A COMPONENT DIMENSIONS: 1.5" X 12" RESISTANCE PER TRACE: < 1 OHM SERPENTINE BUS BEND RADIUS LIMITATION: NONE THICKNESS: APPROX. 10 MILS MAX CURRENT PER TRACE: 1A COMPONENT DIMENSIONS: 3" X 10" RESISTANCE PER TRACE: < 2 OHM ELONGATION: UP TO 20% The S-bus is perfect for when you need to make an unusual geometry from our LEL buses. You can use two together to make a big C curve to go around an elbow, or just use one to route wiring where you need it for soft robotics or for an installation. The C-Curve bus is perfect for connecting two .15" buses together at a wide angle. Try using this part for creating conductive lines over shoulders or over large surface areas. The straight 4-wire bus has 4 leads that are each .15" wide. Each "wire" is super low resistance, giving you fast data speed and solid wattage without heating up. Each bus is twistable, drapable and bendable for all of your soft circuit needs and this bus can be easily soldered to the S-curve bus or obtuse angle bus to make different shapes of traces for wearable tech applications. This serpentine has .15" traces making it compatible with our S-curve and obtuse bus samples. Use this bus when you need a little more stretch as it has up to 10% elongation. We suggest this bus for our pressure sensors 06 MeGA Pressure Matrix DATASHEET Like the mini pressure sensor... but bigger! Our 3x3 mega pressure matrix has 6 leads, allowing you to map which point you are at in the 3x3 matrix and get a pressure mapping over a surface. Each area has an analog readout that varies depending on the weight of the item on the pressure sensor. Generally, sensor values will read from 500Kohms to 100ohms depending on the force put onto the sensor. MATERIALS: INSULATION: THERMOPLASTIC POLYURETHANE INNER CONDUCTOR: PROPRIETARY INTERCONNECT : ENIG FLEX PCB PRESSURE SENSITIVE MATERIAL: PROPRIETARY PINOUT: DATA: BEND RADIUS LIMITATION: NONE THICKNESS: APPROX 20MILS OPERATING VOLTAGE RANGE: 3.7V-5V PRESSURE RANGE: 0.2LBS - 10LBS COMPONENT DIMENSIONS: 5" X 6.5" SENSING AREA DIMENSIONS: 3" X 3" RESISTANCE VS PRESSURE FOR EACH MATRIX SQUARE GRAMS OF FORCE 150 200 250 300 350 400 450 500 6350 10,886 13,607 RESISTANCE (IN OHMS) 180,000 70,000 27,000 18,000 RECOMMENDED 15,000 OPERATING 13,000 RANGE 13,500 13,000 1,000 600 300 OPERATING NOTES: DO NOT WASH O NOT CUT WHEN USED WITH DO NOT DISASSEMBLE DO NOT SEW DO NOT EXPOSE TO TEMPERATURES ABOVE 150 DEGREES F NOT REUSABLE - STICKING AND DE-STICKING OR DESOLDERING WILL CAUSE DAMAGE FOR PROTOTYPING ONLY. ALL DATA IS APPROXIMATE AND THESE PARTS ARE NOT DESIGNED FOR PRODUCTION USE. USE CARE WHEN SOLDERING. LONG EXPOSURE TO HEAT WILL CAUSE DELAMINATION DO NOT SOLDER ON TOP OF A TEXTILE Our parts are produced by hand. There can be significant variation between units. Please use this data only as a reference, as your part's exact values may differ. 5V - 7.2V Heater DATASHEET The 5V - 7.2V heater is made to work with an off the shelf, 5V battery pack or two lipo batteries in series (just make sure both can output 2A safely). The heater will get hotter depending on the voltage you use. The heater warms up quickly with tangible heat within 60 seconds and top heat after 2 min. Use this component for heating wearables, or for thermochromic effects. MATERIALS: INSULATION: THERMOPLASTIC POLYURETHANE INNER CONDUCTOR: PROPRIETARY INTERCONNECT : RIGID-FLEX PCB DATA: BEND RADIUS LIMITATION: NONE THICKNESS: APPROX 10 MILS OPERATING VOLTAGE RANGE: 5V - 7.2V CURRENT PULL: 1A - 2A TEMPERATURE RANGE: 125F - 165F COMPONENT DIMENSIONS: 6" X 6" HEATING PROFILE PINOUT: 30 SECONDS 2 MINUTES 5V 1.14 A 1.06 A OPERATING NOTES: DO NOT WASH DO NOT CUT DO NOT DISASSEMBLE DO NOT SEW DO NOT EXPOSE TO TEMPERATURES ABOVE 150 DEGREES F 7.2 V NOT REUSABLE - STICKING AND DE-STICKING OR DESOLDERING WILL CAUSE DAMAGE FOR PROTOTYPING ONLY. ALL DATA IS APPROXIMATE AND THESE PARTS ARE NOT DESIGNED FOR PRODUCTION USE. USE CARE WHEN SOLDERING. LONG EXPOSURE TO HEAT WILL CAUSE DELAMINATION DO NOT SOLDER ON TOP OF A TEXTILE 1.60 A 1.46 A Our parts are produced by hand. There can be significant variation between units. Please use this data only as a reference, as your part's exact values may differ. 06 SINGLE BACKLIT BUTTON DATASHEET The single backlit button is a simple mechanical switch that comes with an LED inside. When you press the button, the circuit is completed, driving your pin high or low. Use the embedded LED to make a glowing power icon, logo , or whatever suits your fancy. MATERIALS: INSULATION: THERMOPLASTIC POLYURETHANE INNER CONDUCTOR: PROPRIETARY INTERCONNECT : ENIG FLEX PCB PINOUT: OPERATING NOTES: DO NOT WASH DO NOT CUT DO NOT DISASSEMBLE SINGLE BACKLIT BUTTON BEND RADIUS LIMITATION: .5" AROUND BUTTON AREA THICKNESS: APPROX 1 MM AT BUTTON OPERATING VOLTAGE RANGE: 5V COMPONENT DIMENSIONS: 2" X 3" BUTTON DIMENSIONS: 1" DIAMETER CIRCLE DURABILITY: 10,000 PRESSES UNDER 5LBF USE SUGGESTION TIP: Use a cut-out vinyl sticker or other kind of mask to make backlit logos from your button. DO NOT SEW DO NOT EXPOSE TO TEMPERATURES ABOVE 150 DEGREES F NOT REUSABLE - STICKING AND DE-STICKING OR DESOLDERING WILL CAUSE DAMAGE FOR PROTOTYPING ONLY. ALL DATA IS APPROXIMATE AND THESE PARTS ARE NOT DESIGNED FOR PRODUCTION USE. USE CARE WHEN SOLDERING. LONG EXPOSURE TO HEAT WILL CAUSE DELAMINATION DO NOT SOLDER ON TOP OF A TEXTILE Our parts are produced by hand. There can be significant variation between units. Please use this data only as a reference, as your part's exact values may differ.
COM-17862 价格&库存
很抱歉,暂时无法提供与“COM-17862”相匹配的价格&库存,您可以联系我们找货
COM-17862
  • 1+315.978291+40.76381
库存:1
