SEN-18364
SEN-18364
    SPARKFUNELECTRONICS
    SIP-4
    湿度温度传感器 0 ~ 100% 相对湿度 I²C ±3% RH 8 s 通孔
SEN-18364 数据手册
Data Sheet DHT20 Humidity and Temperature Module • Relative humidity and temperature output • Superior sensor performance, typical accuracy RH: ±3%, T: ±0.5℃ • Fully calibrated and processed digital output, I²C protocol • Wide voltage support 2.2 to 5.5V DC • Excellent long-term stability • Fast-response and anti-interference capability Product Summary DHT20 is a new upgraded product of DHT11, equipped with a dedicated ASIC sensor chip, a high-performance semiconductor silicon-based capacitive humidity sensor and a standard onchip temperature sensor, and uses a standard I 2 C data output signal format. Its performance has been greatly improved and has exceeded the reliability level of the previous generation sensor(DHT11).The new generation of upgraded products have been improved to make their performance more stable in high temperature and high humidity environments; at the same time, the accuracy, response time, and measurement range of the product have been greatly improved. Each sensor is rigorously calibrated and tested before leaving the factory to ensure and satisfy customer’s large-scale applications. 1 Product Description The DHT20 is a kind of sensor of humidity and temperature with digital I²C output. It can be applied to HVAC, dehumidifier, testing and inspection equipment, consumer products, automobiles, automatic control, data loggers, weather stations, home appliances, humidity control, medical and other application fields which need to detect and control temperature and humidity. Figure 1. DHT20 www.aosong.com Version:V1.0 —— May 2021 1 / 13 DHT20 Data Sheet 2 Sensor Specifications Relative Humidity Parameter Condition Min Typical Value Max Unit Resolution Typical - 0.024 - %RH Accuracy Typical - ±3 - %RH Tolerance1 Max - %RH See Figure 2 Repeatable - - ±0.1 - %RH Hysteresis - - ±1 - %RH Nonlinear - -
SEN-18364
物料型号: DHT20
器件简介: - DHT20是DHT11的升级产品,具有ASIC传感器芯片、高性能半导体硅电容式湿度传感器和标准片上温度传感器。 - 它使用标准的I2C数据输出信号格式,性能大幅提升,尤其在高温高湿环境下表现更稳定。
引脚分配: - VDD: 电源供应(2.2V至5.5V) - SDA: 串行数据双向端口 - GND: 地 - SCL: 串行时钟双向端口
参数特性: - 湿度分辨率: 0.024%RH - 湿度准确度: ±3%RH - 温度分辨率: 0.01℃ - 温度准确度: ±0.5℃
功能详解: - DHT20适用于需要检测和控制温度和湿度的领域,如暖通空调、除湿器、测试和检测设备等。 - 传感器在出厂前经过严格的校准和测试。
应用信息: - 焊接时禁止使用回流焊或波峰焊,推荐使用低温焊料。 - 存储条件应避免高浓度化学蒸气,推荐在原包装中存储。
封装信息: - 传感器型号: DHT20 - 封装: 托盘包装,每托盘100PCS
其他注意事项: - 传感器对静电敏感,使用时需采取必要的防静电措施。 - 公司提供12个月的质量保证,直接购买者在保修期内如产品存在缺陷,公司将提供免费维修或更换。
SEN-18364 价格&库存
很抱歉,暂时无法提供与“SEN-18364”相匹配的价格&库存,您可以联系我们找货
