SEN-15870
SEN-15870
    SPARKFUNELECTRONICS
    SLAMTEC MAPPER DEVELOPER KIT - L
SEN-15870 数据手册
2019-11-29 rev.1.2 SLAMTEC Mapper Laser Mapping Sensor Introduction and Datasheet(PREVIEW) Model: M1M1 20M SLAM 3.0 SharpEdge www.slamtec.com Shanghai Slamtec.Co.,Ltd Contents CONTENTS ................................................................................................................................................................... 1 INTRODUCTION .......................................................................................................................................................... 3 SYSTEM COMPOSITION AND CONNECTION ................................................................................................................................ 4 MECHANISM .................................................................................................................................................................................. 4 SAFETY AND SCOPE ....................................................................................................................................................................... 6 DATA OUTPUT ............................................................................................................................................................................... 6 APPLICATION SCENARIOS ............................................................................................................................................................. 6 SPECIFICATION ........................................................................................................................................................... 7 MEASUREMENT PERFORMANCE ................................................................................................................................................... 7 LASER POWER SPECIFICATION ...................................................................................................................................................... 7 OPTICAL WINDOW ........................................................................................................................................................................ 8 COORDINATE SYSTEM DEFINITION OF SCANNING DATA .......................................................................................................... 8 COMMUNICATION INTERFACE ...................................................................................................................................................... 9 OTHER PARAMETERS ................................................................................................................................................................... 11 SELF-PROTECTION AND STATUS DETECTION ................................................................................................. 12 SDK AND SUPPORT ................................................................................................................................................. 13 MECHANICAL DIMENSIONS.................................................................................................................................. 14 REVISION HISTORY .................................................................................................................................................. 15 APPENDIX ................................................................................................................................................................... 16 IMAGE AND TABLE INDEX............................................................................................................................................................ 16 Introduction SLAMTEC Mapper is a new type of laser sensor introduced by SLAMTEC, which is different from traditional LIDAR. It has built-in functions of simultaneous localization and mapping (SLAM), and is suitable for many applications such as robot navigation and positioning, environmental mapping and hand-held measurement. SLAMTEC Mapper uses high-performance SLAM map optimization engine and SharpEdge™ fine mapping technology, which can actively detect and correct closed-loop, and achieve 100,000 square meters high-precision map and pose. SLAMTEC Mapper can work without additional sensors or data input. Because of the built-in 9-DOF inertial navigation system, SLAMTEC Mapper in the hand-held mapping mode can work normally in fluctuating environment with inclination, to ensure the best map data quality. SLAMTEC Mapper provides a complete SDK development kit, mobile phone and PC-side evaluation tools to facilitate users to expand development and data acquisition. At the same time, combined with the supporting ROS driver, the generated map and pose data can be directly used in the ROS environment, which is fully compatible. SLAMTEC Mapper can be directly used as a LIDAR sensor in addition to its own mapping and positioning functions. Through SDK or ROS node, the LIDAR data can be quickly accessed to users'existing systems. 3 / 16 Copyright (c) 2009-2013 RoboPeak Team Copyright (c) 2013-2019 Shanghai Slamtec Co., Ltd. System Composition and Connection SLAMTEC Mapper developer kit includes LIDAR sensors and data processing units. Users only need to connect to 5V DC power supply, then with Ethernet or WiFi SLAMTEC Mapper can be easily communicated. SLAMTEC Mapper developer kit supports DC power supply for DC sockets. Users can obtain real-time map and pose data generated by SLAMTEC Mapper through WiFi signal, and can also realize high-speed and stable data path through Ethernet interface. LIDAR Data Processing Unit Figure 1-1 SLAMTEC Mapper System Composition Mechanism SLAMTEC Mapper developer kit uses SLAMTEC's unique SLAM optimization algorithm and high-performance LIDAR to fuse map data more than 10 times per second and construct up to 100,000 square meters of mapping area. The LIDAR carries out 7000 measurements per second, and the longest ranging distance can reach 20 meters. The built-in processing system can process data in real time and output high-precision map and pose. 4 / 16 Copyright (c) 2009-2013 RoboPeak Team Copyright (c) 2013-2019 Shanghai Slamtec Co., Ltd. Figure 1-2 Block Diagram of working principle of SLAMTEC Mapper Driven by the motor mechanism, the SLAMTEC Mapper's ranging core will rotate clockwise to achieve 360-degree omni-directional map of the surrounding environment. * Note: There is no direct connection and disproportionate relationship between the sensor mapping and the environmental schematic here. This is for illustrative purposes only. Figure 1-3 The Obtained Environment Map from SLAMTEC Mapper 5 / 16 Copyright (c) 2009-2013 RoboPeak Team Copyright (c) 2013-2019 Shanghai Slamtec Co., Ltd. Safety and Scope SLAMTEC Mapper uses a low-power infrared laser as the emission source and is driven by a modulated pulse mode. The laser can only launch in a very short time. Class I Therefore, it can ensure the safety of humans and pets, and can meet the Class I level of laser safety standards. The product conforms to 21 CFR 1040.10 and 1040.11, except for deviation according to Laser Notice No. 50 of 24 June 2007. Caution: Use of controls or adjustments or performance of procedures other than those specified herein may result in hazardous radiation exposure. The modulated laser can effectively avoid the interference from ambient light and sunlight during ranging scanning process, which makes SLAMTEC Mapper work excellent in all kinds of indoor environment and outdoor environment without direct sunlight. Data Output SLAMTEC Mapper developer kit can achieve 0.05m resolution and less than 0.02m positioning accuracy, and can actively detect and correct the closed-loop by using SLAMTEC's high-performance SLAM map optimization engine and SharpEdge™ fine mapping technology. The output data includes real-time LIDAR scanning data, real-time map data, real-time pose coordinates (x, y, theta) and positioning quality. With SLAMWARE SDK or ROS Node driver, relevant data can be obtained. Application Scenarios SLAMTEC Mapper can be used in the following application scenarios: o General robot navigation and localization o Environment mapping o Architectural engineering 6 / 16 Copyright (c) 2009-2013 RoboPeak Team Copyright (c) 2013-2019 Shanghai Slamtec Co., Ltd. Specification Measurement Performance For Model M1M1 Only Item Detail Parameter Distance Range1 The largest distance measured by radar 20m Sample Rate Laser points sampled per second by radar 7000 Hz Maximum Area Maximum Mapping Area 300m * 300m 2 Mapping resolution Maximum moving speed Maximum rotation speed 0.05m Maximum Linear Speed of Product Mobility Maximum angular velocity of product rotation 1 m/s TBD Accuracy < 0.02m Graph Optimizing Working Time3 Maximum Inclination Angle Frequency of data refresh About 1hr Maximum Inclination Angle in Mapping Process Frequency of data and location information updates ±3° 8 Hz Figure 2-1 SLAMTEC Mapper Performance Laser Power Specification For Model M1M1 Only Item Unit Min Typical Max Comments Laser wavelength Nanometer(nm) 895 905 915 Infrared Light Band Laser power4 Watt (W) - 28 - Peak power Pulse length Nanosecond(ns) - 10 - - - - Duty Ratio Laser Safety Class 0.007 - - IEC-60825 Class 1 Figure 2-2 SLAMTEC Mapper Specification 1 Measured at 92% reflectivity Each pixel in the map represents an area of 0.05m x 0.05m 3 Depending on the difference of environment, beyond the time limit, it will enter the non-graph optimization mapping mode. 4 Laser power is instantaneous, and the actual average power will be much lower than this value. 2 7 / 16 Copyright (c) 2009-2013 RoboPeak Team Copyright (c) 2013-2019 Shanghai Slamtec Co., Ltd. Optical Window To make SLAMTEC Mapper working normally, please ensure proper space to be 5 left for its emitting and receiving laser lights when designing the host system . The obscuring of the host system for the ranging window will impact the performance and resolution of SLAMTEC Mapper. If you need cover the SLAMTEC Mapper with translucent materials or have other special needs, please contact SLAMTEC about the feasibility. Optical Window Figure 2-3 SLAMTEC Mapper Window Coordinate System Definition of Scanning Data SLAMTEC Mapper adopts a coordinate system that follows the right-hand rule. The front of the sensor is defined as the x-axis of the coordinate system, and the origin of the coordinate system is the rotation center of the ranging core. Specific coordinate system definitions are shown in the following figure: X Y Figure 2-4 SLAMTEC Mapper Scanning Data Coordinate System Definition 5 You can check the Mechanical Dimensions chapter for detailed window dimensions. 8 / 16 Copyright (c) 2009-2013 RoboPeak Team Copyright (c) 2013-2019 Shanghai Slamtec Co., Ltd. Communication interface SLAMTEC Mapper uses a separate 5V DC power supply. Through simple plugand-play functions, users can connect it to mobile devices such as mobile phones to create an integrated portable measurement scheme. Specific interface definitions and ontology lines are shown in the following figure: Figure 2-5 SLAMTEC Mapper Developer Kit Interface Definition Diagram Figure 2-6 SLAMTEC Mapper Developer Kit Power Wire Diagram 9 / 16 Copyright (c) 2009-2013 RoboPeak Team Copyright (c) 2013-2019 Shanghai Slamtec Co., Ltd. Power Supply Interface SLAMTEC Mapper developer kit supports DC power supply for DC sockets. External power supply needs to ensure that the current output ability and ripple characteristics of the power supply meet the requirements of the table below to ensure the normal use of the map sensor. For Model M1M1 Only Item Unit Min Typical Max Remark Power Voltage V - 5 - If the voltage exceeds the max value, it may damage the core Power Voltage Ripple mV - 20 50 High ripple may cause the core working failure. System Start Current mA 1400 1500 1600 TBD TBD TBD 5V Power,power off 450 500 1000 5V Power,power on Power Current mA Figure 2-8 SLAMTEC Mapper Power Supply Specification Data communication interface SLAMTEC Mapper communicates with WiFi over Ethernet. Its transmission standards and rates are shown in the following table: Interface Standard Rate Ethernet 802.3/802.3u 10/100M WiFi 802.11a/b/g/n/ac - Figure 2-9 SLAMTEC Mapper Interface Specification 10 / 16 Copyright (c) 2009-2013 RoboPeak Team Copyright (c) 2013-2019 Shanghai Slamtec Co., Ltd. Other parameters For Model M1M1 Only Item Unit Min Typical Max Weight Gram (g) TBD 230 TBD Degree Celsius (oC) -5 25 45 Degree Celsius (oC) TBD TBD TBD Working temperature range Storage temperature range Comments Figure 2-10 SLAMTEC Mapper Other Parameters 11 / 16 Copyright (c) 2009-2013 RoboPeak Team Copyright (c) 2013-2019 Shanghai Slamtec Co., Ltd. Self-protection and Status Detection When SLAMTEC Mapper is not working properly, users can get the working status of the system through SDK health data acquisition interface, and try to restart SLAMTEC Mapper to restore work. 12 / 16 Copyright (c) 2009-2013 RoboPeak Team Copyright (c) 2013-2019 Shanghai Slamtec Co., Ltd. SDK and Support In order to facilitate users to use SLAMTEC Mapper for product development and accelerate the development cycle, SLAMTEC provides RoboStudio, a software for robot management and development, which can be debugged graphically through network connection. In addition, SDK development kit which can run on X86 windows, x86 Linux, arm Linux and other platforms is also provided to users. For specific information, please contact SLAMTEC. Figure 4-1 RoboStudio 13 / 16 Copyright (c) 2009-2013 RoboPeak Team Copyright (c) 2013-2019 Shanghai Slamtec Co., Ltd. Mechanical Dimensions The mechanical dimensions of the SLAMTEC Mapper are shown as below: Figure 5-1 SLAMTEC Mapper Mechanical Dimensions 14 / 16 Copyright (c) 2009-2013 RoboPeak Team Copyright (c) 2013-2019 Shanghai Slamtec Co., Ltd. Revision history Date Version Description 2019-7-19 1.0 Initial version for SLAMTEC Mapper 2019-11-26 1.1 Added the current value of working current in Table 2-7 2019-11-29 1.2 Modify figure 2-3 SLAMTEC Mapper window 15 / 16 Copyright (c) 2009-2013 RoboPeak Team Copyright (c) 2013-2019 Shanghai Slamtec Co., Ltd. Appendix Image and Table Index FIGURE 1-1 SLAMTEC MAPPER SYSTEM COMPOSITION ............................................................................................................. 4 FIGURE 1-2 BLOCK DIAGRAM OF WORKING PRINCIPLE OF SLAMTEC MAPPER ......................................................................... 5 FIGURE 1-3 THE OBTAINED ENVIRONMENT MAP FROM SLAMTEC MAPPER ............................................................................ 5 FIGURE 2-1 SLAMTEC MAPPER PERFORMANCE........................................................................................................................... 7 FIGURE 2-2 SLAMTEC MAPPER SPECIFICATION ........................................................................................................................... 7 FIGURE 2-3 SLAMTEC MAPPER WINDOW.................................................................................................................................... 8 FIGURE 2-4 SLAMTEC MAPPER SCANNING DATA COORDINATE SYSTEM DEFINITION ............................................................ 8 FIGURE 2-5 SLAMTEC MAPPER DEVELOPER KIT INTERFACE DEFINITION DIAGRAM ................................................................. 9 FIGURE 2-6 SLAMTEC MAPPER DEVELOPER KIT POWER WIRE DIAGRAM................................................................................. 9 FIGURE 2-8 SLAMTEC MAPPER POWER SUPPLY SPECIFICATION.............................................................................................. 10 FIGURE 2-9 SLAMTEC MAPPER INTERFACE SPECIFICATION ...................................................................................................... 10 FIGURE 2-10 SLAMTEC MAPPER OTHER PARAMETERS............................................................................................................. 11 FIGURE 4-1 ROBOSTUDIO .............................................................................................................................................................. 13 FIGURE 5-1 SLAMTEC MAPPER MECHANICAL DIMENSIONS .................................................................................................... 14 Manufacturer: SHANGHAI SLAMTEC CO., LTD. Address: D-501 Shengyin Tower, 666 Shengxia Rd., Shanghai, China Made in China 16 / 16 Copyright (c) 2009-2013 RoboPeak Team Copyright (c) 2013-2019 Shanghai Slamtec Co., Ltd.
SEN-15870 价格&库存
很抱歉,暂时无法提供与“SEN-15870”相匹配的价格&库存,您可以联系我们找货
