R
High precision
Professional GNSS wireless solutions provider
GNSS Antenna
Model:TOP106
High-precision GNSS Antenna
STOTON
TOPGNSS TOP106 four-system 7-band measurement antenna can simultaneously support
GNSS multi-frequency signals: GPS L1, L2 and Beidou B1, B2, B3 / GLONASS L1 L2
frequency band signals. The multi-feed antenna design ensures the coincidence of the
antenna phase center and the geometric center and improves the measurement accuracy.
Built-in low-noise amplifier module, pre-stage and multi-stage filters can filter out interference
signals to ensure normal operation in harsh electromagnetic environments. The radome is
made of high-temperature-resistant PC material.
The plastic adopts a streamlined design and is widely used in geodetic surveying, bridge
construction, ocean surveying, underwater topographic surveying, unmanned aerial vehicles,
unmanned vehicles, unmanned ships and other high-precision positioning and navigation
timeout fields.
1.Antenna characteristics
频率范围
1555~1615MHz /1198~1278MHz
(Frequency Range)
端口阻抗(port Impedance)
50 Ohm
极化方式
(Polarization)
右旋圆极化 (RHCP)
天线轴比
(Axial Ratio)
≤3dB
水平面覆盖角度 (Elevation Coverage)
360°
电压驻波比
≤2
(VSWR)
天线单元增益 (Gain of Antenna)
≥5dBi
相位中心误差 (Phase Center Error)
±2mm
低噪放增益
40±2dB
噪声系数
(LNA Gain)
≤1.5dB
(Noise Figure)
输出驻波
(VSWR)
≤1.5
输入驻波
(VSWR)
≤1.5
增益平坦度
(Gain Flatness)
±1dB
输出P1dB压缩点(Pout at 1dB Gain
Compression Point)
≥0dBm
工作电压 (LNA Drain Voltage)
3.3-12VDC
工作电流 (LNA Current Consumption)
≤45mA
差分传输延迟(delay)差分传输延迟(delay)
很抱歉,暂时无法提供与“GPS-18380”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6811.505601+867.53320
