S TYPE LOAD CELL
Features:
◆Capacity :5~5000kg
◆Material: alloy steel
◆Type: compressiom and tension
◆Defend grade: IP66.
◆Application: portable scales , tension or compression
measuring applications and other electronic weighing
devices.
Electrical connection and Dimensions:(dimension unit: mm)
Cap/kg
A
B
C
M
5~50
51
12.7
64
M8
100~500
51
19
76
M12
750~1500
50.8
25.4
76
M12*1.75
2000~5000
76.2
25.4
108
M18*1.5
Specifications:
capacity
kg
5,10,20,30,50,100,150,200,300,500,1T,1.5T,2T,3T,5T
safe overload
%FS
150
ultimate overload
%FS
200
2.0 ± 0.005
9~ 12
rated output
mV/V
excitation voltage
Vdc
combined error
%FS
zero balance
non-linearity
%FS
± 0.03
± 1.0
%FS
± 0.03
hysteresis
%FS
± 0.03
repeatability
%FS
creep
%FS/30min
± 0.03
± 0.024
350 ± 5
input resistance
Ω
output resistance
Ω
350 ± 3
insulation resistance
MΩ
≥ 5000 @ 100 Vdc
operating temperature range
-10 ~ +40
compensated temperature range
-20 ~ +55
temperature coefficient of SPAN
%FS/10℃
± 0.023
temperature coefficient of ZERO
%FS/10℃
± 0.023
4 core shielded PVC cable, Ø 5 × 3m
cable
excitation(+):Red excitation(-):Black
signal(+):Green signal(-):White
※Ordering code: model-capacity- rated output-accuracy-defend grade- the length of cable
WWW.HTC-SENSOR.COM
TAS501
很抱歉,暂时无法提供与“SEN-14282”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1239.11640
- 200+494.42400
- 500+477.90000
- 1000+469.73520
