KIT-14036
KIT-14036
    SPARKFUNELECTRONICS
    COMPUTER KIT GRAY 14" HD LCD
KIT-14036 数据手册
pi-topCEED Welcome Welcome to the pi-top family! INSTRUCTION MANUAL pi-topCEED is very special to us (and so are you, of course!). We are hugely passionate about this product and are thrilled to provide excellent content so you can learn to make anything. Your support has helped to make this a reality and we thank you for joining us on this exciting maker journey! We believe pi-topCEED is the best way to get started with hardware and software. Open up your box and immediately immerse yourself in a new way of exploring computing unlocking a world of possibilities. As you grow and learn, pi-topCEED will be part of your journey to expand your knowledge - the only limit is your imagination! Follow this side if your pi-topCEED has GPIO Breakout Cable. So, let’s get started! Set up your pi-topCEED following our manual so you can log-in and start your own cool projects, play our educational game CEEDuniverse and more! Step through the world’s gateway to technology. With love, The pi-top Team This cable makes your pi-topCEED compaitble with pi-top Add-ons. Getting Ready: What’s in the Box? pi-topCEED Step 1: Inserting MicroSD Card MICRO COMPUTER Power Supply YOU WILL NEED GPIO CARD *MICRO SD CARD X4 *MAG CLIPS X4 OPTIONAL ADD-ONS pi-topPROTO pi-topSPEAKER *Warning: Small parts can be choking hazards and should be kept away from children under 3 yr old. Step 3: Preparing pi-topCEED Step 2: Inserting Mag Clips Push Mag Clips into your Micro Computer. Remove the Acylic Slice from your pi-topCEED. Step 4: Connecting HDMI Cable Connect the HDMI Cable into your Micro Computer. Step 5: Inserting Micro Computer Place your Micro Computer onto the Mag Rail and slide it to the end. Ensure the two Mag Clips on the right are lifted over the bumps at the end of the Mag Rail. Step 6: Connecting GPIO Step 7: Sliding in Acrylic Slice Step 8: Adjusting Kick Stand Step 9: Connecting Power Supply Adjust the Kick Stand so your pi-topCEED sits on a desk at a comfortable viewing angle. Plug in the Power Supply and hold the Power Button beside it for 2-3 seconds to turn on your pi-topCEED. You can now begin your journey into the world of computing! Step 10: Place pi-top Add-ons on the Mag Rails Place your pi-top Add-on on the Mag Rails and slide it towards the Hub PCB. pi-topCEED Welcome Welcome to the pi-top family! INSTRUCTION MANUAL pi-topCEED is very special to us (and so are you, of course!). We are hugely passionate about this product and are thrilled to provide excellent content so you can learn to make anything. Your support has helped to make this a reality and we thank you for joining us on this exciting maker journey! We believe pi-topCEED is the best way to get started with hardware and software. Open up your box and immediately immerse yourself in a new way of exploring computing unlocking a world of possibilities. As you grow and learn, pi-topCEED will be part of your journey to expand your knowledge - the only limit is your imagination! Follow this side if your pi-topCEED has jumper cables. So, let’s get started! Set up your pi-topCEED following our manual so you can log-in and start your own cool projects, play our educational game CEEDuniverse and more! Step through the world’s gateway to technology. With love, The pi-top Team The jumper cables offer the most flexible usage of your Micro Computer’s GPIO pins. Getting Ready: What’s in the Box? pi-topCEED Step 1: Inserting MicroSD Card MICRO COMPUTER Power Supply YOU WILL NEED Remove the Micro SD Card from the adapter and insert into the slot underneath your Micro Computer. GPIO CARD *MICRO SD CARD *MAG CLIPS X4 X4 OPTIONAL ADD-ONS pi-topPROTO pi-topSPEAKER *Warning: Small parts can be choking hazards and should be kept away from children under 3 yr old. Step 2: Prepare PCBs Step 3: Adding GPIO Card Push Mag Clips into your Micro Computer. Place the GPIO Card onto your Micro Computer. Step 4: Prepare pi-topCEED Step 5: Connecting HDMI Cable Connect the HDMI Cable into your Micro Computer. Remove the Acylic Slice from your pi-topCEED. Connect the the female jumpers onto your Micro Computer. Ensure the arrow on the jumper is facing your Micro Computer to avoid damage. Red 3.3V PWR I2C SDA I2C SDL GPIO 4 GND GPIO 17 GPIO 27 GPIO 22 3.3V PWR SPI MOSI SPI MISO SPI SCLK GND ID_SD GPIO 5 GPIO 6 GPIO 13 GPIO 19 GPIO 26 GND Place your Micro Computer onto the Mag Rail and slide it to the end. Ensure the two Mag Clips on the right are lifted over the bumps at the end of the Mag Rail. Step 7: Connecting GPIO 5V PWR 5V PWR GND UART TX UART RX GPIO 18 GND GPIO 23 GPIO 24 GND GPIO 25 SPI CS0 SPI CS1 ID_SC GND GPIO 12 GND GPIO 16 GPIO 20 GPIO 21 Step 6: Inserting Micro Computer Caution: Take extra care with the 2-pin jumper cable (the one with the red wire), not assembling exactly as shown will cause damage to your Micro Computer / pi-topCEED. Step 8: Sliding in Acrylic Slice Step 9: Adjusting Kick Stand Adjust the Kick Stand so your pi-topCEED sits on a desk at a comfortable viewing angle. Step 9: Connecting Power Supply Plug in the Power Supply and hold the Power Button beside it for 2-3 seconds to turn on your pi-topCEED. You can now begin your journey into the world of computing!
KIT-14036 价格&库存
很抱歉,暂时无法提供与“KIT-14036”相匹配的价格&库存,您可以联系我们找货
