IE122301-1
IE122301-1
    DBUNLIMITED
    插件,D=12mm
    机电元件 蜂鸣器 指示灯,内部驱动 1.5 V 20mA 2.3kHz 80dB @ 1.5V,10cm 通孔 PC 引脚
IE122301-1 数据手册
Insert Graphics Specifications Description Technology Resonant Frequency Value Unit Electro-Mechanical 2,300 (Hz) Rated Voltage 1.5 (V) SPL @ 10cm 80 (dBA) Tone Mount Type Voltage Range Max Rated Current Housing Material Revision History Version Description Date Approved 1 Released from Engineering 10/21/2013 J.S 1) All dimensions are in mm unless otherwise noted 2) All parts meet RoHS Single Thru Hole 1.2 ~ 3 20 (V) (mA) NORYL Operating Temperature -30 ~ +70 °C Storage Temperature -40 ~ +85 °C 2 (g) Weight Notes Drawn by Date Checked by Date Approved by Date A.B. 10/21/2013 C.E. 10/21/2013 J.S 10/21/2013 Electro-Mechanical Indicator IE122301-1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. sales@dbunlimitedco.com | www.dbunlimitedco.com ©2013, DB Unlimited Sheet 1 of 1
IE122301-1 价格&库存
很抱歉,暂时无法提供与“IE122301-1”相匹配的价格&库存,您可以联系我们找货
