4
3
2
1
Part Number:
DRAWN
5/20/2019
CJ
IE330403-1
CHECKED
5/21/2019
C.H.
Description:
APPROVED
Electro-Mechanical Indicator
5/21/2019
C.E.
D
D
This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written
permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com
Top View
Side View
15.5
17
C
Bottom View
C
120
23
33.5
XX X
27.5
2
Black
Red
B
A
5
B
Date Code Marking
"19 E"
19=2019, E=May
2 - n2
Items
Specifications
Conditions
Min. Sound Pressure Level
70
dB (@ 10cm)
Tone
Single
Resonant Frequency
400
Hz
Rated Voltage
3
V
Voltage Range
2~4
V
Max. Rated Current
mA
Storage Temperature
-20 ~ +70
°C
Operating Temperature
-20 ~ +65
°C
REVISION HISTORY
REV
DESCRIPTION
DATE
Released from Engineering
10/21/2013
J.S.
1
Updated to new drawing template, weight, temps
5/21/2019
C.E.
2
Updated max. rated current
11/16/2021
P.D.
NOTES
Connection Method
Lead Wires
1) All dimensions are in mm unless otherwise noted
Mount Type
Flange Mount
2) All tolerances are ± 0.5 mm unless otherwise noted
Housing Material
ABS
Weight
8
4
APPROVED
3) All parts meet RoHS
g
3
4) Subject to change or redrawn without notice
2
1
Additional considerations can be found at www.dbunlimitedco.com/technical-articles.
A
很抱歉,暂时无法提供与“IE330403-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+49.671001+6.42381
