4
3
2
1
Part Number:
DRAWN
IP224512-1
12/5/2017
CJ
CHECKED
12/6/2017
P.D.
Description:
D
APPROVED
Piezo Indicator
12/6/2017
C.E.
This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written
permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com
Bottom View
Side View
Top View
D
32
27.5
C
C
10.8
Date Code Marking
"17 L"
17=2017, L=Dec.
1.8
Ø22
2.5
3.2
Black
B
Red
B
3
100
Wire: UL1007, AWG#26
A
Items
Specifications
Conditions
Min. Sound Pressure Level
95
dB (@ 10cm)
Tone
Single
Resonant Frequency
4,500 ± 500
Hz
Rated Voltage
12
V
Voltage Range
3 ~ 30
V
Max. Rated Current
3
mA
Storage Temperature
-20 ~ +60
°C
NOTES
Operating Temperature
-20 ~ +60
°C
1) All dimensions are in mm unless otherwise noted
REVISION HISTORY
REV
1
DESCRIPTION
DATE
Released from Engineering
10/21/2013
J.S.
Update flange hole shape, drawing template
12/6/2017
C.E.
2) All tolerances are ± 0.5 mm unless otherwise noted
Connection Method
Lead Wires
Mount Type
Flange Mount
3) All parts meet RoHS
Housing Material
ABS
4) Subject to change or redrawn without notice
Weight
5
4
APPROVED
g
3
2
1
Additional considerations can be found at www.dbunlimitedco.com/technical-articles.
A
很抱歉,暂时无法提供与“IP224512-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+31.196761+4.03905
