IP403212-1
IP403212-1
    DBUNLIMITED
    插件,D=40mm
    压电 蜂鸣器 指示灯,内部驱动 12 V 30mA 3.2kHz 110dB @ 12V,10cm 通孔 PC 引脚
IP403212-1 数据手册
Insert Graphics Specifications Description Value Unit Technology Piezo Resonant Frequency 3,200 (Hz) Rated Voltage 12 (V) SPL @ 10cm 110 (dBA) Tone Mount Type Voltage Range 1) All dimensions are in mm unless otherwise noted 2) All parts meet RoHS Version Description Date Approved 1 Released from Engineering 10/21/2013 J.S Single Thru Hole 5 ~ 18 Max Rated Current 30 Housing Material ABS (V) (mA) Operating Temperature -20 ~ +60 °C Storage Temperature -30 ~ +70 °C 8 (g) Weight Revision History Notes Piezo Indicator Drawn by Date Checked by Date Approved by Date A.B. 10/21/2013 C.E. 10/21/2013 J.S 10/21/2013 IP403212-1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. sales@dbunlimitedco.com | www.dbunlimitedco.com ©2013, DB Unlimited Sheet 1 of 1
IP403212-1 价格&库存
很抱歉,暂时无法提供与“IP403212-1”相匹配的价格&库存,您可以联系我们找货
