4
3
2
1
Part Number:
DRAWN
7/26/2018
CJ
MM032602-1
CHECKED
8/16/2018
C.H.
Description:
APPROVED
Digital MEMS Microphone
8/16/2018
C.E.
D
D
This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written
permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com
2.65
0.98
Bottom View
1.68
0.13
2.24
C
5
1
4
2
3.50
3.12
0.13
R0.25
0.73
C
0.52
Side View
0.30
Top View
3
0.33
1.04
1.03
1.63
0.73
B
Pin 1
DATA
Items
Specifications
Directivity
Omnidirectional
Sensitivity
A
B
1.33
-26
Pin 2
L/R
Pin 3
GND
Pin 4
CLOCK
Pin 5
VDD
Conditions
1
dB
Frequency Range
100 ~ 10,000
Hz
Rated Voltage
2
V
Voltage Range
1.6 ~ 3.6
V
Max. Rated Current
640
A
Power Supply Rejection
-90
dBFS (A)
Storage Temperature
-40 ~ +105
C
NOTES
Operating Temperature
-40 ~ +105
C
1) All dimensions are in mm unless otherwise noted
Signal to Noise Ratio
64
dB
Max. Rated Current (SLEEP mode)
4
A
Mount Type
Surface Mount
Connection Method
4
Surface Mount Pads
REVISION HISTORY
REV
DESCRIPTION
DATE
APPROVED
Released from Engineering
8/16/2018
C.E.
2) All tolerances are
0.1 mm unless otherwise noted
3) All parts meet RoHS
4) Subject to change or redrawn without notice
3
2
1
A
很抱歉,暂时无法提供与“MM032602-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+27.230191+3.51519
- 10+21.4356510+2.76717
- 25+19.5174925+2.51955
- 50+18.2023450+2.34977
- 100+16.98951100+2.19321
- 250+16.69519250+2.15521
