MM034202-7
MM034202-7
    DBUNLIMITED
    30 Hz ~ 10 kHz 模拟 麦克风 MEMS(硅) 全向 (-42dB) 焊盘
MM034202-7 数据手册
4 3 2 1 Part Number: DRAWN 6/19/2018 CJ MM034202-7 CHECKED 6/20/2018 C.H. Description: APPROVED Analog MEMS Microphone D 6/20/2018 C.E. This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com 2.95 1.10 1.70 0.50 2.55 C R0.25 4 2 3 2.46 3.76 1 1.50 0.30 3.36 1.18 C Bottom View Side View Top View D Pick Area 4 - 0.80 B B 0.80 1.90 Pin 1 VDD A Items Specifications Directivity Omnidirectional Pin 2 GND Pin 3 GND Pin 4 OUTPUT Conditions Sensitivity -42 dB Frequency Range 30 ~ 10,000 Hz Rated Voltage 2 V Voltage Range 1.6 ~ 3.6 V Output Impedance 300 Ω Max. Rated Current 0.08 mA Power Supply Rejection -90 dB NOTES Storage Temperature -40 ~ +105 °C 1) All dimensions are in mm unless otherwise noted Operating Temperature -40 ~ +105 °C 2) All tolerances are ± 0.5 mm unless otherwise noted Signal to Noise Ratio 60 dB Mount Type Surface Mount Connection Method 4 Surface Mount Pads REVISION HISTORY REV 1 DESCRIPTION DATE APPROVED Released from Engineering 6/20/2018 C.E. Power Supply Rejection added 8/6/2018 C.E. 3) All parts meet RoHS 4) Subject to change or redrawn without notice 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
MM034202-7 价格&库存
很抱歉,暂时无法提供与“MM034202-7”相匹配的价格&库存,您可以联系我们找货
