MO044002-1
MO044002-1
    DBUNLIMITED
    100 Hz ~ 16 kHz 模拟 麦克风 驻极体电容 全向 (-40dB) 非焊接(Bullseye)
MO044002-1 数据手册
Insert Graphics Specifications Description Value Unit Directivity Omnidirectional Technology Electret Condenser Sensitivity Frequency Range Rated Voltage -40 (dB) (Hz) 2 (V) 2,200 Connection Method Solderless Voltage Range 1) All dimensions are in mm unless otherwise noted 2) All parts meet RoHS 100 ~ 16,000 Output Impedance 2 ~ 10 Notes Revision History Version Description Date Approved 1 Released from Engineering 10/21/2013 J.S (Ohm) (V) Max Rated Current 0.5 (mA) Drawn by Date Checked by Date Approved by Date Minimum Signal to Noise Ratio >60 (dB) A.B. 10/21/2013 C.E. 10/21/2013 J.S 10/21/2013 Operating Temperature -20 ~ +70 °C Storage Temperature -40 ~ +85 °C Electret Condenser Microphone sales@dbunlimitedco.com | www.dbunlimitedco.com ©2013, DB Unlimited MO044002-1 Sheet 1 of 1
MO044002-1 价格&库存
很抱歉,暂时无法提供与“MO044002-1”相匹配的价格&库存,您可以联系我们找货
MO044002-1
  • 1+12.449971+1.61060
  • 10+9.7667110+1.26348
  • 25+8.8832625+1.14919
  • 50+8.2774250+1.07081
  • 100+7.71674100+0.99828
  • 250+7.04374250+0.91122
  • 500+6.93532500+0.89719
库存:960
