MO062504-1
MO062504-1
    DBUNLIMITED
    50 Hz ~ 16 kHz 模拟 麦克风 驻极体电容 全向 () 导线引线
MO062504-1 数据手册
4 3 2 1 Part Number: DRAWN MO062504-1 3/8/2018 CJ CHECKED 3/15/2018 C.H. Description: Electret Condenser Microphone D APPROVED 3/15/2018 C.E. This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View D Bottom View Side View 2.2 ± 0.2 Ø6.0 ± 0.2 C 50 ± 3 C (+) (-) Red Black Wire:UL1571, AWG#30 B B Connector:51021-0200 or equivalent Schematic Mic Case C Term. 1 Output RL A Items Specifications Directivity Omnidirectional 10pF 33pF Conditions Sensitivity -25 ± 3 dB Frequency Range 50 ~ 16,000 Hz Rated Voltage 4.5 V Voltage Range 1 ~ 10 V Output Impedance 2,200 Ω +Vs Ground Term. 2 REVISION HISTORY REV 1 DESCRIPTION DATE Released from Engineering 10/21/2013 J.S. Updated to new drawing template 3/15/2018 C.E. Max. Rated Current 0.5 mA NOTES Storage Temperature -25 ~ +70 °C 1) All dimensions are in mm unless otherwise noted Operating Temperature -20 ~ +60 °C 2) All tolerances are ± 0.5 mm unless otherwise noted Signal to Noise Ratio 60 dB Mount Type Flush Mount Connection Method 4 Connector APPROVED 3) All parts meet RoHS 4) Subject to change or redrawn without notice 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
MO062504-1 价格&库存
很抱歉,暂时无法提供与“MO062504-1”相匹配的价格&库存,您可以联系我们找货
