MO064001-1
MO064001-1
    DBUNLIMITED
    50 Hz ~ 16 kHz 模拟 麦克风 驻极体电容 全向 () PC 引脚
MO064001-1 数据手册
Insert Graphics Specifications Description Value Unit Directivity Omnidirectional Technology Electret Condenser Sensitivity Frequency Range Rated Voltage Impedance 1) All dimensions are in mm unless otherwise noted 2) All parts meet RoHS -40 (dB) 50 ~ 16,000 (Hz) 1.5 (V) 2,200 Connection Method PC Pins Voltage Range 1.5 ~ 10 Notes Revision History Version Description Date Approved 1 Released from Engineering 10/21/2013 J.S (Ohm) (V) Max Rated Current 0.5 (mA) Drawn by Date Checked by Date Approved by Date Minimum Signal to Noise Ratio >60 (dB) A.B. 10/21/2013 C.E. 10/21/2013 J.S 10/21/2013 Operating Temperature -20 ~ +60 °C Storage Temperature -25 ~ +70 °C Electret Condenser Microphone MO064001-1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. sales@dbunlimitedco.com | www.dbunlimitedco.com ©2013, DB Unlimited Sheet 1 of 1
MO064001-1 价格&库存
很抱歉,暂时无法提供与“MO064001-1”相匹配的价格&库存,您可以联系我们找货
