4
3
2
1
Part Number:
DRAWN
3/31/2016
CJ
MO064202-2
CHECKED
4/1/2016
P.D.
Description:
Electret Condenser Microphone
D
APPROVED
4/1/2016
J.S.
This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written
permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com
Top View
Bottom View
Side View
5.20 ± 0.20
C
D
0.20 ± 0.10
C
Filter
6.00
Terminal 1 (+)
Terminal 2 (-)
B
A
B
Items
Specifications
Directivity
Omnidirectional
Conditions
Sensitivity
-42
dB
Frequency Range
50 ~ 16,000
Hz
Rated Voltage
2
V
Voltage Range
1 ~ 10
V
REVISION HISTORY
REV
DESCRIPTION
DATE
Released from Engineering
10/21/2013
J.S.
1
Updated height and Template
4/1/2016
P.D.
2
Corrected Signal to Noise Ratio
5/24/2017
C.E.
Output Impedance
2,200
Ω
Max. Rated Current
0.5
mA
NOTES
Storage Temperature
-20 ~ +60
°C
1) All dimensions are in mm unless otherwise noted
Operating Temperature
-10 ~ +50
°C
2) All tolerances are ± 0.5 mm unless otherwise noted
> 58
Mount Type
Flush Mount
Connection Method
4
Solder Pads
APPROVED
3) All parts meet RoHS
dB
4) Subject to change or redrawn without notice
3
2
1
Additional considerations can be found at www.dbunlimitedco.com/technical-articles.
A
很抱歉,暂时无法提供与“MO064202-2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+19.330981+2.50257
- 10+14.6620910+1.89814
- 25+13.2018525+1.70910
- 50+12.2168450+1.58158
- 100+11.32085100+1.46559
- 300+10.06147300+1.30255
- 500+9.53488500+1.23438
- 1000+8.874101000+1.14883
- 5000+7.834085000+1.01419
