MO094204-1
MO094204-1
    DBUNLIMITED
    50 Hz ~ 16 kHz 模拟 麦克风 驻极体电容 全向 (-42dB) PC 引脚
MO094204-1 数据手册
4 3 2 1 Part Number: DRAWN 8/10/2017 CJ MO094204-1 CHECKED 8/14/2017 P.D. Description: Electret Condenser Microphone D APPROVED 8/14/2017 C.E. This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View C Bottom View Side View Ø9.7 ± 0.2 C 6.5 ± 0.2 2.5 ± 0.2 4.5 ± 0.2 D Terminal 1 (+) A 0.45 ± 0.05 Terminal 2 (-) B B 0.35 ± 0.05 DETAIL A A Items Specifications Directivity Omnidirectional Conditions Sensitivity -42 ± 2 dB Frequency Range 50 ~ 16,000 Hz Rated Voltage 4.5 V Voltage Range 1 ~ 10 V REVISION HISTORY REV 1 DESCRIPTION Released from Engineering Add Pin Dimensions, update to new template, voltage range changed NOTES DATE 10/21/2013 APPROVED J.S. 8/14/2017 C.E. Output Impedance 2,200 Ω Max. Rated Current 0.5 mA Storage Temperature -25 ~ +70 °C 1) All dimensions are in mm unless otherwise noted Operating Temperature -20 ~ +60 °C 2) All tolerances are ± 0.5 mm unless otherwise noted Signal to Noise Ratio 60 dB Mount Type Thru Hole Connection Method 4 PC Pins 3) All parts meet RoHS 4) Subject to change or redrawn without notice 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
MO094204-1 价格&库存
很抱歉,暂时无法提供与“MO094204-1”相匹配的价格&库存,您可以联系我们找货
