4
3
2
1
Part Number:
DRAWN
MU064602-2
CJ
CHECKED
P.D.
Description:
Electret Condenser Microphone
D
APPROVED
C.E.
2/28/2017
2/28/2017
2/28/2017
This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written
permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com
C
Top View
Side View
Ø6.00 ± 0.10
3.50 ± 0.20
D
Bottom View
C
Terminal 1 (+)
Terminal 2 (-)
0.20 ± 0.10
B
A
B
Items
Specifications
Directivity
Unidirectional
Conditions
Sensitivity
-46 ± 4
dB
Frequency Range
100 ~ 10,000
Hz
Rated Voltage
2
V
Voltage Range
1 ~ 10
V
REV
Output Impedance
2,200
Ω
1
Max. Rated Current
0.5
mA
Storage Temperature
-20 ~ +60
°C
1) All dimensions are in mm unless otherwise noted
Operating Temperature
-10 ~ +50
°C
2) All tolerances are ± 0.5 mm unless otherwise noted
Signal to Noise Ratio
>55
dB
Mount Type
Flush Mount
Connection Method
4
Solder Pads
REVISION HISTORY
DESCRIPTION
Released from Engineering
Update to new template, correct to 4 holes
NOTES
DATE
10/21/2013
2/28/2017
APPROVED
J.S.
C.E.
3) All parts meet RoHS
4) Subject to change or redrawn without notice
3
2
1
Additional considerations can be found at www.dbunlimitedco.com/technical-articles.
A
很抱歉,暂时无法提供与“MU064602-2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+21.864441+2.83079
- 10+17.1728110+2.22337
- 25+15.6319625+2.02387
- 50+14.5740250+1.88690
- 100+13.59913100+1.76068
- 300+13.03314300+1.68741
