4
3
2
1
Part Number:
DRAWN
6/9/2020
CJ
MW043002-1
CHECKED
6/10/2020
P.D.
Description:
APPROVED
Waterproof Microphone
D
6/10/2020
J.S.
D
This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written
permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com
Top View
Bottom View
Side View
1.8 ± 0.2
Ø4.6 ± 0.2
1.5 ± 0.2
Terminal 1 (+)
Terminal 2 (-)
C
Ø4.0 ± 0.2
C
IP67 Cloth Barrier
Ø2.0
Sealing Epoxy
100 ± 3
B
Red (+)
Black (-)
Rubber Holder
ECM Unit
B
C
Term. 1
Output
WIRE: UL1571, AWG#30
RL
A
Term. 2
Ground
Items
Specifications
Directivity
Omnidirectional
Conditions
1
C1 C2
C1: 10PF
C2: 33PF
+Vs
Sensitivity
-30 ± 3
dB
Frequency Range
50 ~ 16,000
Hz
Rated Voltage
2
V
Voltage Range
1 ~ 10
V
Output Impedance
2,200
Ω
Max. Rated Current
500
uA
IP Rating
IP67
Storage Temperature
-25 ~ +70
Operating Temperature
-20 ~ +60
°C
1) All dimensions are in mm unless otherwise noted
Signal to Noise Ratio
60
dB
2) All tolerances are ± 0.5 mm unless otherwise noted
Mount Type
Flush Mount
3) All parts meet RoHS
Connection Method
4
Lead Wires
4) Subject to change or redrawn without notice
REVISION HISTORY
REV
1
DESCRIPTION
DATE
APPROVED
Released from Engineering
6/10/2020
J.S.
Dimension added to top view
12/29/2020
J.S.
°C
3
NOTES
2
1
Additional considerations can be found at www.dbunlimitedco.com/technical-articles.
A
很抱歉,暂时无法提供与“MW043002-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+20.802441+2.69112
- 10+15.7950810+2.04334
- 25+14.2300325+1.84088
- 50+13.1692450+1.70365
- 100+12.20503100+1.57891
- 300+10.84953300+1.40356
- 500+10.28290500+1.33025
- 1000+9.571761000+1.23826
- 5000+8.521865000+1.10244
