4
3
2
1
Part Number:
DRAWN
MW043602-2
10/13/2021
CJ
CHECKED
11/01/2021
P.D.
Description:
APPROVED
Waterproof Microphone
D
11/01/2021
J.S.
D
This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written
permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com
Top View
Bottom View
Side View
4.0
Ø4.6 ± 0.2
0.4
1.8 ± 0.2
1.5 ± 0.2
1.4 ± 0.2
Term. 1 (+)
C
Ø0.40 ± 0.05
Ø4.0 ± 0.2
C
IP67 Cloth Barrier
2.0
Term. 2 (-)
Rubber Holder
B
Sealing Epoxy
B
ECM Unit
C
Term. 1
Output
RL
C1 C2
A
C1: 10PF
C2: 33PF
+Vs
Term. 2
Ground
Items
Specifications
Directivity
Omnidirectional
Conditions
Sensitivity
-36 ± 3
dB
Frequency Range
50 ~ 16,000
Hz
Rated Voltage
2
V
Voltage Range
1 ~ 10
V
Output Impedance
2,200
Ω
Max. Rated Current
500
uA
IP Rating
IP67
Storage Temperature
-25 ~ +70
Operating Temperature
Signal to Noise Ratio
Mount Type
Thru Hole
Connection Method
4
PC Pins
REVISION HISTORY
REV
DESCRIPTION
DATE
APPROVED
Released from Engineering
11/01/2021
J.S.
NOTES
°C
1) All dimensions are in mm unless otherwise noted
-20 ~ +60
°C
2) All tolerances are ± 0.5 mm unless otherwise noted
60
dB
3) All parts meet RoHS
4) Subject to change or redrawn without notice
3
2
1
Additional considerations can be found at www.dbunlimitedco.com/technical-articles.
A
很抱歉,暂时无法提供与“MW043602-2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+13.809981+1.78669
- 10+10.4110110+1.34695
- 25+9.3663825+1.21179
- 50+8.6600350+1.12041
- 100+8.01825100+1.03738
- 300+7.11760300+0.92086
- 500+6.74165500+0.87222
- 1000+6.269761000+0.81116
- 5000+5.323305000+0.68871
