MW062502-1
MW062502-1
    DBUNLIMITED
    50 Hz ~ 16 kHz 模拟 麦克风 驻极体电容 1 V ~ 10 V 全向 (-25dB ±3dB) 导线引线
MW062502-1 数据手册
4 3 2 1 Part Number: DRAWN 6/9/2020 CJ MW062502-1 CHECKED 6/10/2020 P.D. Description: APPROVED Waterproof Microphone D 6/10/2020 J.S. D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Bottom View Side View 3.5 ± 0.2 2.7 ± 0.2 IP67 Cloth Barrier Terminal 1 (-) Terminal 2 (+) Ø2.5 6 ± 0.2 Ø6.7 ± 0.2 C Ø7.2 ± 0.2 C Sealing Epoxy Mic. 100 ± 3 B Red (+) Black (-) Rubber Holder ECM Unit B C Term. 1 Output RL A +Vs Ground Items Specifications Directivity Omnidirectional WIRE: UL1571, AWG#30 C1: 10PF C2: 33PF Conditions 1 C1 C2 Term. 2 Sensitivity -25 ± 3 dB Frequency Range 50 ~ 16,000 Hz Rated Voltage 2 V Voltage Range 1 ~ 10 V Output Impedance 2,200 Ω Max. Rated Current 500 uA IP Rating IP67 Storage Temperature -25 ~ +70 Operating Temperature -20 ~ +60 °C 1) All dimensions are in mm unless otherwise noted Signal to Noise Ratio 60 dB 2) All tolerances are ± 0.5 mm unless otherwise noted Mount Type Flush Mount 3) All parts meet RoHS Connection Method 4 Lead Wires 4) Subject to change or redrawn without notice REVISION HISTORY REV 1 DESCRIPTION DATE APPROVED Released from Engineering 6/10/2020 J.S. Dimension added to side view 12/29/2020 J.S. °C 3 NOTES 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
MW062502-1 价格&库存
很抱歉,暂时无法提供与“MW062502-1”相匹配的价格&库存,您可以联系我们找货
MW062502-1
  • 1+13.951181+1.80427
  • 10+10.9549410+1.41677
  • 25+9.9641625+1.28864
  • 50+9.2861350+1.20095
  • 100+8.65849100+1.11978
  • 250+7.90451250+1.02227
  • 500+7.88440500+1.01967
库存:1717
