SC250708-1
SC250708-1
    DBUNLIMITED
    8 Ohms 通用 扬声器 1 W 200 Hz ~ 20 kHz 顶部 矩形
SC250708-1 数据手册
4 3 2 1 Part Number: DRAWN SC250708-1 10/29/2015 CJ CHECKED 11/17/2015 P.D Description: High Temp Dynamic Speaker D APPROVED 11/17/2015 J.S This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Bottom View Side View Top View D 5.00 ± 0.20 16.00 4.50 ± 0.10 13.00 2.00 ± 0.20 4 - 1.80 22.00 C 25.00 C B A B Items Specifications Conditions Sound Pressure Level 96 dB (@ 10cm) Resonant Frequency 750 Hz Frequency Range 200 ~ 20,000 Hz Nominal Power 1 W Max. Power 1.3 W Ω Impedance 8 Cone Material Cloth REVISION HISTORY REV 1 DESCRIPTION DATE Released from Engineering 2/8/2014 J.S. New template, correct to show no wires 3/17/2017 C.E. NOTES 1) All dimensions are in mm unless otherwise noted Mount Type Frame Mount Storage Temperature -40 ~ +85 °C 3) All parts meet RoHS Operating Temperature -40 ~ +85 4) Subject to change or redrawn without notice Weight 5 °C g 4 APPROVED 2) All tolerances are ± 0.5 mm unless otherwise noted 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
SC250708-1 价格&库存
很抱歉,暂时无法提供与“SC250708-1”相匹配的价格&库存,您可以联系我们找货
SC250708-1
  • 1+26.125451+3.37873
