SC240908-1
SC240908-1
    DBUNLIMITED
    8 Ohms 通用 扬声器 500 mW 900 Hz ~ 20 kHz 顶部 矩形
SC240908-1 数据手册
4 3 2 1 Part Number: DRAWN SC240908-1 4/7/2016 CJ CHECKED 4/11/2016 P.D. Description: D APPROVED Dynamic Speaker 4/11/2016 J.S. This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Side View 14.90 D Bottom View 3.60 12.00 24.90 Silk Screen Marking "16 D" 16=2016, D=Apr. 22.00 C 11.30 C B B 4 - 1.50 5.00 A Items Specifications Conditions Sound Pressure Level 95 dB (@ 10cm) Resonant Frequency 900 Hz Frequency Range 900 ~ 20,000 Hz Nominal Power 0.5 W Max. Power 1 W Impedance 8 Ω Cone Material Cloth REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 10/21/2013 J.S. SPL Updated 2/11/2016 J.S. 1 NOTES 1) All dimensions are in mm unless otherwise noted Mount Type Frame Mount Storage Temperature -20 ~ +50 °C 3) All parts meet RoHS Operating Temperature -20 ~ +50 4) Subject to change or redrawn without notice Weight 2 °C g 4 2) All tolerances are ± 0.5 mm unless otherwise noted 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
SC240908-1 价格&库存
很抱歉,暂时无法提供与“SC240908-1”相匹配的价格&库存,您可以联系我们找货
SC240908-1
    • 1+42.236561+5.46395
    • 10+32.2989210+4.17836
    • 25+29.1611125+3.77244
    • 50+27.0344050+3.49732
    • 100+25.09633100+3.24660
    • 300+22.36343300+2.89305
    • 500+21.21903500+2.74501
    • 1000+19.780461000+2.55891
    库存:104
    SC240908-1
    • 1+37.097511+4.79913
    • 10+29.2176410+3.77975
    • 25+26.6288425+3.44485
    • 72+23.9596372+3.09955
    • 144+23.58825144+3.05150
    库存:29
