SC400408-1
SC400408-1
    DBUNLIMITED
    8 Ohms 通用 扬声器 1 W 450 Hz ~ 20 kHz 顶部 矩形
SC400408-1 数据手册
4 3 2 1 Part Number: DRAWN SC400408-1 8/9/2016 CJ CHECKED 8/9/2016 P.D. Description: D APPROVED Dynamic Speaker 8/9/2016 J.S. This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Side View Bottom View 5.80 ± 0.30 20.00 ± 0.20 1.60 ± 0.15 16.00 ± 0.20 40.00 ± 0.20 Ø14.50 ± 0.30 C 36.00 ± 0.20 C B A D B Items Specifications Conditions Sound Pressure Level 89 ± 3 dB (@ 10cm) Resonant Frequency 450 Hz Frequency Range 450 ~ 20,000 Hz Nominal Power 1 W Max. Power 2 W Impedance 8 Ω Cone Material Cloth REVISION HISTORY REV 1 DESCRIPTION DATE APPROVED Released from Engineering 2/5/2014 J.S. Updated to new template 8/9/2016 J.S. NOTES 1) All dimensions are in mm unless otherwise noted Mount Type Flush Mount Storage Temperature -40 ~ +80 °C 3) All parts meet RoHS Operating Temperature -40 ~ +70 4) Subject to change or redrawn without notice Weight 7.6 °C g 4 2) All tolerances are ± 0.5 mm unless otherwise noted 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
SC400408-1 价格&库存
很抱歉,暂时无法提供与“SC400408-1”相匹配的价格&库存,您可以联系我们找货
SC400408-1
