SM151708-1
SM151708-1
    DBUNLIMITED
    8 Ohms 通用 扬声器 300 mW 1.7 kHz ~ 20 kHz 顶部 圆形
SM151708-1 数据手册
4 3 2 1 Part Number: DRAWN SM151708-1 2/13/2019 CJ CHECKED 2/15/2019 C.H. Description: D APPROVED Dynamic Speaker 2/15/2019 C.E. This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Side View Ø15 ± 0.2 C D Bottom View 7.5 ± 0.3 C 7.6 ± 0.2 XX X Ø0.80 ± 0.05 + _ Date Code Marking "19 B" 19=2019, B=Feb. 9 - 1.50 ± 0.2 B B 6 A Items Specifications Conditions Sound Pressure Level 92 dB (@ 10cm), Avg. Resonant Frequency 1,700 Hz Frequency Range 1,700 ~ 20,000 Hz Nominal Power 0.3 W Max. Power 0.5 W Impedance 8 Ω Cone Material Mylar REVISION HISTORY REV DESCRIPTION DATE Released from Engineering 2/8/2014 J.S. 1 Updated to new drawing template, SPL 2/15/2019 C.E. 2 Updated temps 5/29/2019 C.E. NOTES Mount Type Thru-Hole Storage Temperature -30 ~ +70 °C 2) All tolerances are ± 0.5 mm unless otherwise noted Operating Temperature -20 ~ +60 Weight 2 °C g 4) Subject to change or redrawn without notice 4 APPROVED 1) All dimensions are in mm unless otherwise noted 3 3) All parts meet RoHS 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
SM151708-1 价格&库存
很抱歉,暂时无法提供与“SM151708-1”相匹配的价格&库存,您可以联系我们找货
SM151708-1
    • 1+41.142291+5.32544
    • 10+31.4575410+4.07185
    • 25+28.3974925+3.67576
    • 50+26.3233650+3.40729
    • 100+24.43414100+3.16275
    • 300+21.77189300+2.81815
    • 500+20.65681500+2.67381
    • 1000+19.255431000+2.49242
