SP400804-4
SP400804-4
    DBUNLIMITED
    4 Ohms 通用 扬声器 2 W 800 Hz ~ 10 kHz 顶部 椭圆,矩形框架
SP400804-4 数据手册
4 3 2 1 Part Number: DRAWN 12/15/2018 CJ SP400804-4 CHECKED 12/21/2018 C.H. Description: APPROVED Dynamic Speaker 12/21/2018 C.E. D D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Bottom View Side View Top View 15 30 0.3 C 40 0.3 C XX X Date Code Marking "18 L" 18=2018, L=Dec. 1 48 5 Wire: UL1571,AWG#28 B Black (-) 1.5 Red (+) B A Items Specifications Conditions Sound Pressure Level 100 dB (@ 10cm) Resonant Frequency 800 Hz Frequency Range 800 ~ 10,000 Hz Nominal Power 2 W Max. Power 3 W Impedance 4 NOTES Cone Material Paper + Cloth 1) All dimensions are in mm unless otherwise noted Mount Type Flush Mount Storage Temperature -30 ~ +70 C 3) All parts meet RoHS Operating Temperature -20 ~ +60 4) Subject to change or redrawn without notice Weight 12.2 C g 4 REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 12/21/2018 C.E. 2) All tolerances are 3 2 0.5 mm unless otherwise noted 1 A
SP400804-4 价格&库存
很抱歉,暂时无法提供与“SP400804-4”相匹配的价格&库存,您可以联系我们找货
SP400804-4
  • 1+47.292981+6.11807
  • 10+37.2186310+4.81480
  • 25+33.9295125+4.38930
  • 50+31.6664150+4.09654
  • 100+30.90442100+3.99796
库存:15
