4
3
2
1
Part Number:
DRAWN
3/23/2017
CJ
SW280708-1
CHECKED
10/2/2017
P.D.
Description:
APPROVED
Waterproof Dynamic Speaker
D
10/2/2017
C.E.
This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written
permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com
Top View
Side View
Ø28 ± 0.2
5.5
Bottom View
2.4 ± 0.2
C
Ø16 ± 0.2
C
XX X
Date Code Marking
"17 C"
17=2017, C=Mar.
Max. Vibration 0.6mm
B
A
D
B
Items
Specifications
Conditions
Sound Pressure Level
92
dB (@ 10cm), Avg.
Resonant Frequency
700
Hz
Frequency Range
700 ~ 10,000
Hz
Nominal Power
1.5
W
Max. Power
2
Impedance
8
Cone Material
Mylar
NOTES
Mount Type
Flush Mount
1) All dimensions are in mm unless otherwise noted
REVISION HISTORY
REV
DESCRIPTION
DATE
APPROVED
Released from Engineering
10/2/2017
C.E.
1
Added polarity marking
10/25/2017
C.E.
W
2
Update markings
2/28/2018
C.E.
Ω
3
Updated temperatures
7/24/2019
C.E.
IP Rating
IP67
Storage Temperature
-30 ~ +65
°C
3) All parts meet RoHS
Operating Temperature
-30 ~ +65
4) Subject to change or redrawn without notice
Weight
6.85
°C
g
4
2) All tolerances are ± 0.3 mm unless otherwise noted
3
2
1
Additional considerations can be found at www.dbunlimitedco.com/technical-articles.
A
很抱歉,暂时无法提供与“SW280708-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+40.641771+5.26066
- 10+32.0102110+4.14339
- 25+29.1778925+3.77678
- 50+27.2252950+3.52403
- 100+26.12441100+3.38154
