SW390608-1
SW390608-1
    DBUNLIMITED
    8 Ohms 通用 扬声器 1.5 W 600 Hz ~ 20 kHz 顶部 椭圆形
SW390608-1 数据手册
4 3 2 1 Part Number: DRAWN SW390608-1 3/23/2017 CJ CHECKED 10/5/2017 P.D. Description: Waterproof Dynamic Speaker D APPROVED 10/5/2017 C.E. This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Side View 29.7 Bottom View 5.5 C 24.8 39.7 C D XX X Date Code Marking "17 C" 17=2017, C=Mar. (+) 4.1 B A B Items Specifications Conditions Sound Pressure Level 95 dB (@ 10cm), Avg. Resonant Frequency 600 Hz Frequency Range 600 ~ 20,000 Hz Nominal Power 1.5 W Max. Power 2 W Impedance 8 Ω Cone Material Mylar NOTES Mount Type Flush Mount 1) All dimensions are in mm unless otherwise noted REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 10/5/2017 C.E. 1 Added polarity marking 10/25/2017 C.E. 2 Update markings 2/28/2018 C.E. IP Rating IP67 Storage Temperature -20 ~ +55 °C 3) All parts meet RoHS Operating Temperature -20 ~ +55 4) Subject to change or redrawn without notice Weight 8.88 °C g 4 2) All tolerances are ± 0.2 mm unless otherwise noted 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
SW390608-1 价格&库存
很抱歉,暂时无法提供与“SW390608-1”相匹配的价格&库存,您可以联系我们找货
