SW400704-1
SW400704-1
    DBUNLIMITED
    4 Ohms 通用 扬声器 2 W 750 Hz ~ 10 kHz 顶部 矩形
SW400704-1 数据手册
4 3 2 1 Part Number: DRAWN SW400704-1 3/23/2017 CJ CHECKED 10/2/2017 P.D. Description: APPROVED Waterproof Dynamic Speaker D 10/2/2017 C.E. D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Side View Bottom View 11.8 28.4 0.3 22.5 9.8 C 0.2 C 0.2 34 40 16.5 0.3 0.3 6.9 XX X _ Date Code Marking "17 C" 17=2017, C=Mar. + B B 3.0 A Items Specifications Conditions Sound Pressure Level 94 dB (@ 10cm), Avg. Resonant Frequency 750 Hz Frequency Range 750 ~ 10,000 Hz Nominal Power 2 W Max. Power 2.5 W Impedance REVISION HISTORY DESCRIPTION DATE APPROVED Released from Engineering 10/2/2017 C.E. 1 Update markings 2/28/2018 C.E. 4 2 Updated side and bottom view 6/17/2019 C.E. Cone Material PET 3 Updated tolerance 7/7/2023 L.L. Mount Type Frame Mount NOTES IP Rating IP67 1) All dimensions are in mm unless otherwise noted Storage Temperature -20 ~ +55 C Operating Temperature -20 ~ +55 Weight 12.56 C g 4 3 REV 2) All tolerances are 0.5 mm unless otherwise noted 3) All parts meet RoHS 4) Subject to change or redrawn without notice 2 1 A
SW400704-1 价格&库存
很抱歉,暂时无法提供与“SW400704-1”相匹配的价格&库存,您可以联系我们找货
