4
3
2
1
Part Number:
DRAWN
TE082305-1
7/13/2015
CJ
CHECKED
11/23/2015
P.D
Description:
Electro-Mechanical Transducer
D
APPROVED
11/23/2015
J.S
This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written
permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com
Top View
Side View (2)
Bottom View
Side View (1)
8.50
4.00
C
D
C
2 - Ø0.75
6.00
1.00
Dummy Pad
Sound Port
Polarity Pad (+)
8.50
6.00
1.41
2.05
0.
30
Polarity Pad (-)
1.30
4
-1
.0
R0.48
1.00
Dummy Pad
3
-0
.9
8
3 - 0.63
B
A
B
Items
Specifications
Conditions
Sound Pressure Level
87
dB (@ 10cm)
Resonant Frequency
2,350
Hz
Rated Voltage
5
V
Voltage Range
3~7
V
Coil Resistance
30
ohm
Max. Rated Current
90
mA
Storage Temperature
-30 ~ +70
°C
NOTES
Operating Temperature
-30 ~ +70
°C
1) All dimensions are in mm unless otherwise noted
Connection Method
Surface Mount Pads
Mount Type
Surface Mount
3) All parts meet RoHS
Housing Material
LCP
4) Subject to change or redrawn without notice
Weight
0.6
4
REVISION HISTORY
REV
1
DESCRIPTION
DATE
APPROVED
Released from Engineering
10/21/2013
J.S.
Updated to new template
11/23/2015
J.S.
2) All tolerances are ± 0.5 mm unless otherwise noted
g
3
2
1
Additional considerations can be found at www.dbunlimitedco.com/technical-articles.
A
很抱歉,暂时无法提供与“TE082305-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+38.576561+4.99047
