4
3
2
1
Part Number:
DRAWN
6/10/2021
CJ
TP103210-1
CHECKED
6/10/2021
P.D.
Description:
APPROVED
Piezo Transducer
D
6/10/2021
J.S.
D
This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written
permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com
Top View
Bottom View
Side View
3.2
Ø10
C
C
Date Code Marking
"21 F"
21=2021, F=Jun.
XX X
Wire: UL1571, AWG#32
B
5±1
90 ± 3
B
A
Items
Specifications
Conditions
Min. Sound Pressure Level
80
dB (@ 10cm)
Resonant Frequency
3,200
Hz
Rated Voltage
10
V
Voltage Range
1 ~ 30
V
Capacitance
11,000
pF
Max. Rated Current
7
mA
Storage Temperature
-20 ~ +70
°C
Operating Temperature
-20 ~ +60
°C
REVISION HISTORY
REV
1
DESCRIPTION
DATE
APPROVED
Released from Engineering
10/21/2013
J.S.
Updated to new template
6/10/2021
J.S.
NOTES
Connection Method
Lead Wires
1) All dimensions are in mm unless otherwise noted
Mount Type
Flush Mount
2) All tolerances are ± 0.5 mm unless otherwise noted
Housing Material
ABS
Weight
1
4
3) All parts meet RoHS
g
3
4) Subject to change or redrawn without notice
2
1
Additional considerations can be found at www.dbunlimitedco.com/technical-articles.
A
很抱歉,暂时无法提供与“TP103210-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+19.200701+2.48390
- 10+14.6371010+1.89360
- 25+13.1518025+1.70140
- 50+12.0978050+1.56510
- 100+11.22340100+1.45200
- 250+10.25320250+1.32640
- 500+9.11530500+1.17920
- 1000+8.588201000+1.11110
- 5000+7.773705000+1.00570
- 国内价格 香港价格
- 1+18.173161+2.35098
- 10+14.2210410+1.83971
- 25+12.9410025+1.67412
- 50+12.0612150+1.56031
- 100+11.24919100+1.45526
- 300+10.45644300+1.35270
